Roof Swap Complete
    That looks amazing! Congrats
      Need more, better pics! Looks great though congrats.
      -Notice any difference in driveability?
      -Did they reuse the front and rear windhsield? How about the seals?
      The math says a ~5% body roll reduction for an otherwise stock M3
        Oh, I do have a nice (albeit, old) side by side of the Z4M seats vs standards. Had the Z seats reupholstered with Impuls Cloth to keep the spec correct. They are much better than the OG sofas.
        Any chance you took measurements of exactly how much lower the Z4M seats are vs the stock ones at the lowest setting? I'm still chasing a lower seat height and trying to map options! In recaro sportsters now.
          My guess is that the Sportsters are probably as low as the Z4Ms.
          However, when I got my seats, the seat bottom (base) cushion was busted through. The result was a significantly lower seating position. I later added the wire frame support to the underside of the seat, which restored a stock-like seating position. Still lower than the oe seats, but again, probably what you have now.
          Z4M seats with a broken out bottom cushion might be what you’re after. Unorthodox, but much much lower.
            Not my roof, but it is oe . . .
            Click image for larger version  Name:	IMG_3943.jpg Views:	0 Size:	173.5 KB ID:	341418
              Dude, so garbage. Great minds, indeed. The Z4M is the minimum acceptable oe seat, imo. The fact that it’s plug and play power (so my pup can easily hop in the back) with heat made the swap a no brainer.
              Speaking of Kevin at ABS (good dude for sure), I have a new photo to offer bigjae46 . Rest assured, we’re all just getting teasers at the moment.
              Did you need to code out airbag lights or disable the passenger airbag for the Z4m seats?
                Is that the CSL in Paris?
                2005 BMW ///M3
                Black6MT Daily
                  Dude yes, I was gonna PM him about that. Going through that rn with my car and it's annoying as hell.
                  2005 BMW ///M3
                  Black6MT Daily
                    Yep, well spotted. Pretty clean example. Trunk fitment was perfect.
                      It’s been a while, but I think the upholstery shop moved over the occupancy sensor. That or I coded the passenger airbag to always on. Either way, there’s no airbag light on my dash. I don’t dig error lights.
                        Congrats man! Kevin did a great job. I saw this on IG a couple weeks ago. Stoked for you 👌🏽
                          So all we get are 3 pics with no interior pics? Are you kidding me?
                          I want to see more!
                          More pics at last.
                                I would also like to point out that my suspension needed softening after the swap. Finally got to drive it a bit over the weekend and it was noticeably stiffer. Just needed one click, but still.
