Looking to get more insight on this- do E46 M3's have Stability control AND Traction control? The DSC button on my 02 M3 seems to only have one function, and that is turn off traction and the traction warning light illuminates on the dash.
TC/DSC Modes on 2002 M3?
As standard, both units (MK20 and all M3 MK60s) turn of stability and traction control with one short press of the DSC button.Originally posted by eacmen View Post
I thought that MK20 units one button push disables both but on MK60 units you need to long press to fully turn it off? Or am I mistaken?
IF you code on M track mode to a non ZCP MK60 car, then a short press puts it in M track mode and a long press turns both off off.
On a ZCP, the steering wheel button turns on M track mode and a short press of the DSC button turns off stability control and traction control.
On the non M e46s, traction control and stability control are turned off separately using short press vs long press.
Like Obioban said, thats the non-M behavior. The DSC button turns off both on all M3s.Originally posted by eacmen View Post
However, I have noticed that if I hold the DSC button long enough on my 02 M3, stability control and traction control cannot be turned back on until the car is restarted. It seems to be doing the exact same thing that a short press would (so turning off both), but can't be reversed until you switch the car off.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Same with my non-ZCP MK60...it didn't like me pressing the DSC button for a long time.Originally posted by heinzboehmer View Post
