Originally posted by mrgizmo04
“Switch Chain Grip“....stalling out at lights
Originally posted by jet_dogg View PostHis car is factory 6mt.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Originally posted by FBloggs View PostI had a no crank/no start issue that was caused by a failure of the now NLA brown switch.
I have been making do with the non-M switch which means no cruise control.
Recently I had a stalling condition at traffic lights and found on a Schwaben reader, code 50 DME: switch chain, frictional connection.
This is the intake cam sensor failing.
Just something for you to bear in mind.
Switch chain grip is always either the clutch sensor or gear recognition sensor. Cam sensor has nothing to do with it whatsoever. In your case it’s because you’re using the non-M switch.
I was thinking of his stalling problem.
I recently resolved a stalling problem by replacing the intake cam sensor. So in the offchance his clutch module did not fail, he could look at the intake cam sensor. He has recently replaced the intake cam sensor. Which makes my input irrelevant.
Originally posted by lapoune View PostHow is the gear selector switch used by the ecu? Would it cause the same issues as a defective clutch switch? I keep getting a code 80 switch chain grip and difficult starts/hesitation, but my clutch switch works fine in inpa. Any ideas?
Their wired in series so the dme can’t tell which one is bad. If your clutch pedal still seems to work in INPA, then your gear recognition switch might be stuck closed.
Would you happen to know which part number this is?
Originally posted by antknee View Post
i tried googling gear recognition switch and keep coming back to an SMG related part.
Transmission would have to be removed to replace it unfortunately. Personally if it were my car, I'd bypass the switch and code it out rather than bothering with replacement (if it is indeed failed)
23142229113
23142229113
Side note that, to swap out a non working GPS with a working one, you need a 22mm and that can be swapped out without dropping the tranny.
If you have a fresh smg unit with a blind plug that needs to be tapped to be able to accept a GPS, that's a different story.
Youtube DIYs and more
Do you know what the ecu does with the gear info? My Z3MC doesn't have one at all, so curious why the m3 has one with same engine, mss54 etc.
Originally posted by mrgizmo04 View PostSide note that, to swap out a non working GPS with a working one, you need a 22mm and that can be swapped out without dropping the tranny.
Good to know. I remember it looking quite tight back there and I could have sworn on the old forum people had to drop the tranny. Regardless, I think I'll just bypass the sensor if mine ever fails.
Hi Guys, same issue here with my 6MT swap, I put in 61319122701 switch for my car which is the euro switch, I coded out my EWS since the 701 switch does not support the clutch interlock. After putting in the switch, my cruise control is working now, no more fault code “switch chain grip” what so ever.
The stalling issue seem to be gone 90%, and the car idles much more smoothly than before. But every now and then the car still stalls at the red light stop, completely same symptom. Oh BTW my DME software coded to ditch the need of GPS sensor. Any idea what cause the stalling problem ?
