Your 997 GT3 is more tolerable than an E46 M3 with Ohlins R&T? Yeah as the owner of both, either you have defective dampers or the coilovers aren’t set up correctly.
Most comfortable street ONLY suspension setup?
Which height would that be? The standard 13.5/13 F/R?Originally posted by Obioban View PostThe Ohlins basically only work at one specific ride height. First step should be to check bump and droop travel.
Mike
02 M3 Titanium Silver / Black
11 Tundra SuperWhite / Black
I have KW V3 Clubsport. When the car was mostly standard weight it wasn't too bad, but definitely on the stiff side but not unbearable.
I then took about 150kg out of the car and it was stiffer again.
I replaced the front 120N/mm KW springs for Swift 9kg/mm springs and the progressive (about 115N/mm) KW springs for 10kg/mm BC racing beehive springs. I'd say it's perfect now.
In lbs that's:-
Front 685lb down to 500lb
Rear 656lb down to 560lb
Remember tyre side walls makes a big difference to how it rides.
I went from PSS10s to Ohlins and generally found the latter to be more comfortableOriginally posted by Sharocks View PostPSS9's or PSS10's.
I have had my TCK DA's for 15 years and I adore them but they aren't comfy even at the spring rates you're considering.
LOL KW
And contrary to popular belief, Ohlins on the E46 chassis is not great. It's much better on the E9X platform (I have both).
The last option that could work is the a shock and spring setup, but that's pretty nitty gritty for LA.
From what I've seen, most harshness, poor ride quality, etc. is caused by people running too low and running out of travel, running spring rates that are too high, or actually having too little compression damping which makes the car very 'crashy' feeling.
You can have a good track setup that is also comfortable on the street!
- Likes 2
Depends on the camber plates, or lack thereof, and spacers at the bottom. Many setups with the Ohlins require you to be too low to be in the good geometry.Originally posted by nuc1 View PostWhich height would that be? The standard 13.5/13 F/R?
Mike
Easy check:
they have 92mm of total travel up front. If you have 30-40mm of droop when you jack the front end, you’re pretty well optimized for allowing the shocks to work. Ideally that would be >= 13.5 up front, but it often isn’t with the Ohlins. If you got them from 3DM, IIRC he’s now including spacers to address this issue.
… and the rear lets you set travel independent of height, so that’s no issue, properly set up.
Bilstein with stock springs has been great to me. Handles the backroads as well as cross country trips. The only complaints I have are big bumps at low speed-like 30 and under-or that one time I hit a really bad pothole going somewhat north of interstate speeds and had a bit of a hair raising moment.
Typically very comfortable except in above situations.
I would never suggest Ohlins R&T for a daily, or describe it as "comfortable". They have 400/635 linear rates. PSS10 have digressive valving, so they will feel a little firmer on low speed stuff to have better blowoff on high speed hits.. Bilstein offsets this by using progressive spring rates (340/565 if my old notes were correct). This approach is also why stock, or Eibach/Dinan/etc springs work well because softer rates with more travel can allow even something like a B8 damper or the OE Sachs to feel less aggressive than a coilover setup. But bear in mind even those dampers were relatively harsh for the E46 M chassis. That's what originally opened up this market two decades ago...
TCK's are happier the softer you spring them because while they use linear rates they still function as one of the better coilover options for a daily because they are low pressure. IMO anything over 400/500 and the twin tube stuff just doesn't keep up with bigger rates like a monotube can. That is where a monotube can control the platform better but that is also the crossroads of where you have to decide if you want more road or more track.Last edited by jvit27; 06-19-2026, 03:32 PM.
My new TCK SA/Vorshlag setup is definitely more harsh then I would like, but I am running about a 13.25" ride height all around.Originally posted by cobra View PostFrom what I've seen, most harshness, poor ride quality, etc. is caused by people running too low and running out of travel, running spring rates that are too high, or actually having too little compression damping which makes the car very 'crashy' feeling.
More like 13.25R/13&3/8 front
400R/500F springs, its not terrible, but definitely not as complaint on shitty roads as I would have liked.
Maybe I need to raise the fronts to 13.5, but I can't imagine that small change would be too drastic.2004 Silbergrau Metallic 6MT
Totally agree. I started by checking everything, but no issues found. I haven't been a fan of the ride quality since day one, despite more setup checks and changes than I can count.Originally posted by SQ13 View PostYour 997 GT3 is more tolerable than an E46 M3 with Ohlins R&T? Yeah as the owner of both, either you have defective dampers or the coilovers aren’t set up correctly.
The 997 is stiff but never jarring. Hits bump, absorbs bump, settles. The e46 is unsettled by everything and seems to never reach a "settled" state. Oh well.
FWIW, the 997 isn't even the benchmark for proper comfort and handling. That goes to my '71 911. But it's hard to compete with 2200lbs, a rear engine and 205/55/15s all around.
Thank you very much for the detailed response and apologies for the delay. Hugely helpful.Originally posted by sd561 View Post- if I had to do it over again, i'd change nothing. while I don't know what it felt like in brand new in 2006, car is dialed-in in 2026!
Your feedback pushed me over the edge--I'm going to purchase TCK DAs. Figure I might as well get more adjustability (DA vs. SA) to better adapt to my overly specific (or, sensitive) requirements. TC suggests 400/500. I will probably go with 300/500 to start as that yields a 0.99 flat ride computation and should be softer, which is what I'm after.
But, for now, the car is in "time out" for a few months as I have other projects that are more interesting than retreading the M3 suspension path and I have grown tired of the chase. I will follow up here once the switch has been made.Last edited by LSB4Me; 06-27-2026, 02:01 PM.
