Originally posted by andrebxp
Coolant temp at track
Originally posted by Casa de Mesa View PostBe careful with the #8 O-rings that the thermostat housing attaches to:
https://www.realoem.com/bmw/enUS/sho...diagId=11_3010
Part no: 11537830709. I thought I was super careful, but botched one on install. I reassembled everything (EVERYTHING), filled the coolant and watched it start draining out of that front O-ring that attaches to the thermostat housing. I'd buy a spare O-ring or two just in case...
Complete set of Hi-Temp Silicone and Viton O-rings for the S54 Cooling System and Power Steering and SMG Caps!
1- Temp Sensor- 1
2- Bleeder Screw- 1
3- Exp Tank Return Line- 1
4- Water Pump Lines- 2
5- Exp Tank Cap- 2
6- Radiator Hose Fittings- 2
7- Water Pump Pipe “large”- 2
8- Power Steering/SMG Caps- 2
9- Water Pump Tstat Housing- 1
Two squeeze tubes of Super lube.
"Summer Sale" 14 O-rings and Lube for $45 Shipped via Priority 3 Day.
Please send funds via PayPal as a gift or add the 3% Fee to Mrdestny@yahoo.com
I have 100% Feedback on eBay so buy with confidence. Wolfn8tr on eBay: https://www.ebay.com/usr/wolfn8tr
Last edited by WOLFN8TR; 06-24-2020, 12:51 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
I had a similar issue when refreshing my cooling system. When replacing my water pump the small O-ring on one of the two hard pipes leaked causing issues. Come to find out ECS sent two different sizes, the smaller one was installed just before the water pump and it caused air to be sucked into the system and would slightly drip when the car was off. Also those two #8 orings were already subject to compression set in just a months of use when I tore down the system to replace the smaller O-ring. This is the main reason I put together the Hi-Temp O-ring Kits.
Regarding the set in that took place on those o-rings after a couple of weeks/months, to that I say "yay!!". Hard to believe they are spec'ed that way from the factory
Quick update: Didn't have time to do a complete refresh but couldn't skip out on a hpde. Prior to this event I cycled out about 2 reservoirs full of the 50:50 mixture and put in distilled water. With rough calculations was hoping to get it to 60:40 mixture. Also noticed that the coolant might've been slightly overfilled previously took about 3 turkey basters to get the level to start dropping.
Results: Engine temps 3/4 on gauge. Coolant temps rose to 210-215 by the end of full 20 minute sessions. The ambient temp was about 5 degrees cooler outside and little to no traffic on track. Letting the engine cool between sessions was enough to keep going. Also, beat my PB by .7 seconds so I wasn't taking it any easier.
Complete refresh with OE rad and CSF oil cooler will happen in the winter.
Originally posted by jk715 View PostQuick update: Didn't have time to do a complete refresh but couldn't skip out on a hpde. Prior to this event I cycled out about 2 reservoirs full of the 50:50 mixture and put in distilled water. With rough calculations was hoping to get it to 60:40 mixture. Also noticed that the coolant might've been slightly overfilled previously took about 3 turkey basters to get the level to start dropping.
Complete refresh with OE rad and CSF oil cooler will happen in the winter.Build thread: Topaz Blue to Shark Blue
When I see your coolant temps readings of 215f or 224f I wonder if I have overheating issues or I'm too conservative. The needle will stay dead center until 204F, once it gets to over 205F it starts to move to the right, which makes me very uncomfortable, should I not expect it to stay dead center on a hot track day? the higher I've seen it before decided to let it cool down was 210F. At what temp the warning comes up?
Reading through this as I’m trying to figure out where to set my warning thresholds on my Autometer Elite gauge for my S54 swapped E36. I feel like I had it set a bit too low for the warning and was getting distracted by the warning light. I just upped the high warning to 220 and the high over warning to 230.
Ran fine last month in 65f weather. But also added CSL airbox since then.
Youtube DIYs and more
Originally posted by BeardedRyno828 View PostReading through this as I’m trying to figure out where to set my warning thresholds on my Autometer Elite gauge for my S54 swapped E36. I feel like I had it set a bit too low for the warning and was getting distracted by the warning light. I just upped the high warning to 220 and the high over warning to 230.
Our expansion tank cap is 2bar? (29psi). General rule of thumb I've heard is 3 degF for each PSI, so 29PSI would yield an additional 87 degF to the boiling point. Coolant mixture also affects boiling point.
Me personally I would be more worried about what temp risks the head getting warped versus the boiling point. But boiling point is definitely a factor!
Originally posted by eacmen View PostOur expansion tank cap is 2bar? (29psi). General rule of thumb I've heard is 3 degF for each PSI, so 29PSI would yield an additional 87 degF to the boiling point. Coolant mixture also affects boiling point.
If you have liquid coolant circulating then you won’t run into head warping issues. You’re circulating 250-280 degree oil through the head.
You run into problems when coolant boils. It’s like a run away train…boiling coolant drops the pressure which lowers the boiling point and then you get more boiling. All the while temps are spiking and then you run the risk of warping the head.
