Originally posted by Cubieman
Best Halos?
No, but you can get bosch replacement projectors or morimoto's or retrofit any 1 of 10 projectors that are better than the oem ones. They are probably trashed at this point anyway. You can also get replacement surrounds if yours get damaged. The retrofit source has everything you need.Originally posted by Slideways View PostThe stock xenons already have a halo effect around the outer xenon projector housing. In my opinion, angel eyes look tacky as hell on the E36 and E46, not to mention that they will rub through the chrome reflective coating on the xenon lenses and allow light to escape through the damaged area. Those housings are not available separately through BMW.
That said, a high quality kit, properly installed looks good imo. Tacky is an led strip "brow" in the housing or any one of a million econocars on the market trying to look upscale with led strips.
My V4's were too bright for my tastes at night so I wired in the optional auto-dim wire so when the headlights are turned on the AE's dim a bit, or enough to where they aren't blinding to look at head on anymore, which is nice.Originally posted by tnord View Post
bumping this back up as my rings AEs aren't working. Do you think the AE Guy units are too bright at night? They're looking like an attractive option vs the v2s or v4s.2004 Silbergrau Metallic 6MT
Did you have to do any coding for those or was it a simple plug and play? thinking about purchasing themOriginally posted by Tbonem3 View Post
I installed that kit yesterday, no problems. Very white, and good looking for how simple they are.
2018 BMW ///M3 Daytona Violet/Carbon Cloth ZCP + DCT
Plug and play, like all of themDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Only situation you would need to code something in is if your car has the US DRLs enabled (where the high beams are partially lit whenever the headlights are off) and you want to turn that function off and use the angel eyes as DRLs.Originally posted by MTiz View Post
Did you have to do any coding for those or was it a simple plug and play? thinking about purchasing them2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
+1 for Angel Eye guy, quick shipping easy plug and play and no problems so far. I went with the "standard 120." my preference is a bright AE in the daylight (always sunny here in AZ) and wired to the passenger footwell lamp so it goes on when you unlock and fades away when you lock. i actually haven't noticed if it dims when headlights are on, i will have to check that but i dont think it does...2005 6MT Coupe Mystic Blue
Have never heard of anything that do that, would be nice feature. Some can be manually dimmed.Originally posted by jonnypax09 View Posti actually haven't noticed if it dims when headlights are on, i will have to check that but i dont think it does...
According to BMW the amber spectrum is more visibly noticed by the human eye in daytime light than a white spectrum.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - Euro Bumper - Gruppe M CF Intake - Supersprint - M Track Mode
