Looking at options of street friendly bump steering correction tie rod ends. Which are the highest quality built as in metals used, Teflon lined, etc.
Street freindly or best bump steer correction toe rod ends?
Decided to bite the bullet and ordered VAC bumpsteer correction kit, so far very happy after doing the calculations.
- 1.5mm toe-in at 1 5/8th inch compression.
- 1.5mm toe-out at 1 5/8th inch rebound.
- 40mm bumpsteer adjustment
- 0.30lbs weight savings
- Stock tie rod end had 6mm toe-in at 1 5/8th inch compression.
Now I need to source some boots since these will be street driven.
+1 following for the boots setup. I haven't found bump steer a huge issue yet but would be nice to correct it if possible. Basically all the kits are track only so I gave up but if there is a way to protect the heim joints and make it more street friendly than I am in... well i will add it to the list of things I need (read "want") to get when I get a job and some money again haha
The results are not what I expected and my fault for not thinking everything through. Because I did the 35mm bumpsteer correction, I now need to correct the roll center by 35mm but the only way to do that is by getting racing control arms at $1000+ for a pair. Back to the drawing board..
Originally posted by Stock tie rod with 13.5" front ride height11.5": +6.2mm (toe-in) (0.087 degree of toe in per wheel)
12": +3.5mm
12.5": +1.9mm
13": +0.5mm
Static 13.5": 0mm
14": -0.6mm
14.5": -1.0mm
15": -1.0mm (0.014 degree of toe out per wheel)
15 3/8": -0.7mm(toe-out) (0.0098 degree of toe out per wheel)Originally posted by VAC 35mm correction kit with 13.5: front ride height11.5": -2.5mm (toe-out) (0.035 degree of toe out per wheel)
12": -2.0mm (0.028 degree of toe out per wheel)
12.5": -2.0mm
13": -1.0mm
Static 13.5": 0mm
14": +1.0mm
14.5": +2.5mm
15": +3.5mm (0.049 degree of toe in per wheel)
15 3/8": +5mm(toe-in) (0.070 degree of toe in per wheel)
I saw these as well, I am interested by them but i do see that the LCA monoball that you have to replace with the one in their kit is not sealed... so other than saving a tonne of money you are still in a position where you have a unsealed and (unlike the TMS FCABs) is not even greasable so a bit of a stretch to say these are streetable yet... if they used a sealed monoball which i dont see why they cant in that particular setup then this would arguable be a great street bump steer correction solution.Originally posted by eacmen View PostSaw this piece posted on a fb group. No experience with it:
Maybe MRT could look at customising a heim joint seal to suit their kit so they can be sealed: https://sealsit.com/product-category...-rod-end-seal/ I am not desperate enough for the feature at this juncture nor of the financial position to buy their kit and test these out like i might have a year or so ago haha
Sent a message to MRT, their kit looks interesting and I can get seal kits to seal the bearings but I don't like that in order to correct the bumpsteer and roll center you have to substantially quicken the steering rack. I also sent a message to a Canadian company to see if there is any interest in building a complete aluminum spindle that corrects both bumpsteer and roll-center but uses the stock control arm and tie rod end, doubt anything will come out of it but one can try.
I know some analysis was done on the old forum on the csl spindle. Not sure if it might work in your use case though.Originally posted by pawa_k2001 View PostSent a message to MRT, their kit looks interesting and I can get seal kits to seal the bearings but I don't like that in order to correct the bumpsteer and roll center you have to substantially quicken the steering rack. I also sent a message to a Canadian company to see if there is any interest in building a complete aluminum spindle that corrects both bumpsteer and roll-center but uses the stock control arm and tie rod end, doubt anything will come out of it but one can try.
If I remember correctly, CSL spindle gives more static camber or caster, the mounting points for control arm and tie rod end are the same. What we need is a drop spindle where the actual mounting points for control arm and tie rod end is lower.
I do have a Longarce bumpsteer gauge coming this week so I can make better measurements, if someone is willing to borrow me a CSL spindle, I can measure its bumpsteer and compare it to a regular spindle.
Yer I also wasn't super keen on it increasing the steering rate... surely MRT could make a kit where it moved the tie rod to the outer side instead of the inner side and that will slow the steering a touch. when paired with e ZCP/ZHP (or Purple Tag for us RHD folks) that may balance out nicely and correct bump steer... although sealing the joints is still a must.Originally posted by pawa_k2001 View PostSent a message to MRT, their kit looks interesting and I can get seal kits to seal the bearings but I don't like that in order to correct the bumpsteer and roll center you have to substantially quicken the steering rack. I also sent a message to a Canadian company to see if there is any interest in building a complete aluminum spindle that corrects both bumpsteer and roll-center but uses the stock control arm and tie rod end, doubt anything will come out of it but one can try.
Still interested to follow where this goes....
