Originally posted by gabylonfive
I did notice when installing the new pump that the blue spade connector for the ground wire (the smaller of the two in the image below) did seem to be slightly looser when connected to the female end that runs from the original pump housing. The spade connector has an internal tab that you have to make sure mates to the other end, so after hooking the tab, squeezing the shit out of it with pliers, and applying the heat shrink I figured it would be solid enough. I could see someone messing up the electrical connections if they aren't careful, which might account for the failures. It's Step 17 in Radium's install instructions.
Either way, probably best to reach out to them directly. Would be very interested to see what they come back with if they are aware of the issue since I'm running the kit myself.
