Rear axle rebuild/replacement?
    Your mileage may vary, but I did those inner CVs and thought the car was wonderfully tight for about 3k miles. 20k miles later and it feels pretty similar to how it did before I did the inner CVs.
    My car is a daily, but those didn't solve it for me. Play is definitely in the CVs or splines after several inspections. Freshly built diff, driveshaft CV (no play at all), center carrier and guibo otherwise.
      According to some internet sources, BMW started manufacturing these axles again in 2024 and they are becoming available in the market again.
      I’ve seen them on EBay from UK suppliers, and in the US at Bimmerworld. At BW, at the time of this post they will run you $932 or $949 depending on which side
        Yes it seems BMW started manufacturing again, i purchased mine via eBay in some dealer in the UK, got them for about $1,500 shipped to Texas. I kept my old ones and when i get some free time, i'll figure out to rebuild both the inner and outer boots since BMW sold both inner and outer rebuild kits.
          Good idea! Maybe if we’re lucky, someone will start making the CV joints.
          Remember to mark them Left and Right!
            Does anyone know if the two outer silver & black housings (circled in red in photo) can be separated to thoroughly clean the outer mechanism? If so, how?
            Feff
            ​​Click image for larger version
Name:	Axle Shaft.png
            MVP Track Time
              Feff
              I forget where it separates. IIRC, the boot is attached to a silver flange which is pressed on to the CV housing. Its a single assembly from the splines to the CV housing. I cut the boot off and then removed a couple of ball bearings and separated the CV outer from the inner cage which is attached to the axle.
              I think...its been awhile.
                I wish I could help here, but I never did the job myself.
                I remember finding an assortment of videos from far and wide that gave me enough confidence to buy the materials to service that end of the axle… but I never actually did it.
                New axles came back on the market April of last year. It looked like a PITA of a job.
                  For the record and for closure here, I’ve been going strong for about 5k miles on new BMW half shafts from the manufacturing run mentioned above and all is well. Much better than just the CVs, I suppose the splines on the half shafts were worn or didn’t match perfectly.
                    The inners are easy. The outers are a little trickier.
                    Pry off the end plate that the boot is attached to
                    Remove a couple of balls from the CV joint
                    Separate the CV joint
                    Slide the boot onto the shaft
                    I'm missing a lot of little steps. It's not hard, just a massive mess. I couldn't get the pinch clamps on, I think they were for a non-M. Ended up using zip ties until just buying some from slightly larger clamps from McMaster Carr
                      DIY:
                        Did anyone attempt to remove the outers successfully? The method I heard so far was to remove the outer boot, jerk off the axle into a bucket of gasoline to clear out as much of the old grease as possible, blow it out with an air compressor, repack with grease, and slide the new outer boot through the inner side. If there is a way to get the outer cap off and pull it apart that will be better. 3/4 inner CV's I just pulled were pitted and will need new ones.
                          Its been awhile but I think you pull the boot off and then remove the ball bearings and then separate the CV joint? I just remember getting grease everywhere on everything. I spent more time cleaning up than replacing the boots.
                            So in the pic above, I slid the boot back and checked if there's enough space to get the ball bearings out and it didn't seem like there's enough space without removing the circled cap which is maybe a press fit into the outer CV and can be removed? I'm going to try and clear out the old grease and take a closer look.
                            I was told by my WRL buddy that these are the inner CV's so ordered two, I will report back if they are the correct replacement. As far as I know we can't get outer CV replacements, which is why I was hoping to be able to disassemble the outer and check for pitting before throwing them in the new race car.
                              I think you do have to remove the cap.
                              there is a kit with the outer boots…somewhere. The pinch clamps were too small. I have to buy them from McMaster Carr. I probably have a bunch left.
                                Does anyone have experience with the KMP Drivetrain Solutions axles: https://www.bimmerworld.com/Right-Re...ce-E46-M3.html
                                KMP uses a tri-pod in lieu of the CV joint: https://www.kmpdrivetrain.com/drives...-rzeppa-joint/
                                Feff
                                MVP Track Time
