When you lengthen the hose you introduce the possibility of pressure drop depending on the velocity of the fluid. That combined with thicker burkhart oil is likely leading to issues described when combined with the relocation and cold weather.
Only the CH11 fluid should be used with the relocation harness. The burkhart fluid should only be used for SMG pumps in their original position as its thicker viscosity is meant to help in situations where the SMG pump gets too hot where the CH11 becomes less effective.
Also bleeding and adapting the smg unit in the relocation position can be difficult. The unit must be oriented in its original position during bleeding before being mounted in the drug bin.
