Originally posted by Tones
View Post
Vincebar vs. CMP Topside Reinforcement
OMG truth. I bought the cheapest rivet gun I could find at Harbour Freight, my friend and I took turns so the other could rest. If you have some scrap pipe laying around you could put those over the handles for more leverage.Originally posted by Johnvu View PostBar Epoxied and Riveted in place. **One huge suggestion is to get a pneumatic or assisted rivet gun. I almost crapped my pants getting those larger side rivets in place lol.
Another thing I would definitely do is get an epoxy gun and a few mixing tubes, I was able to borrow one from work. The tubes mix the epoxy in the exact ratio needed and are much cleaner than you messing about squeezing it out by hand onto a plate and mixing it with a popsicle.
Imo the best set up for a road car is:- Redish Motorsport plates
- These are high quality and are also tried and tested. Redish themselves have not had any failures since installing these on cars since 2011.
- Vincebar + Gussets
- The bar itself ties in the chassis rails and so relieves load from the RACP
- The gussets address the front internal mig welds behind the rear bench which are generally the first point of failure (but are often missed by garages who offer these repairs)
- Both bar and gussets are bolted to the subframe itself which ensures all 4 points are reinforced
- The set up is not visible and so does not intrude boot space
- The set up has been tried and tested since 2016 with no reported failures.
- Powerflex Yellow/Purple Subframe Bushes
- Recommended by Redish Motorsport who as previously stated have not had any failures
- The durometer of these bushes are spot on (70A/80A). They absorb the torque from the diff without transmitting it into the floor of the car
- If the bushes are too soft then overtime this will exacerbate movement on the mounting points leading to cracking (like the stock ones do), however if they are too hard, you could also be reducing the life of the RACP as the floor is no longer cushioned by the likes of solid bushings.
- Note there were reports of Powerflex Yellow Gen 1 bushes mushrooming, however there have been no reports of this since they were revised in 2017.
- OE (stock) Differential Bushes
- These bushes do not transmit any extra NVH into the cabin unlike polybushes and are good for 80-100,000 miles
- Note there are 3 bushes (and bolts) which should be replaced - (2 rears and 1 front). The rear bushes cannot be bought separately from BMW and so must be bought with the rear diff cover. If not done already, it may also be worth uprating your rear bolts as they were revised by BMW post-production following a PuMA case in 2007.
2002 BMW E46 M3 Coupé
2005 Porsche 911 (997.1) Carrera S
^I agree with most of the above, but I'd skip the power flexsubframe bushings. Since 2017 isn't enough time to prove them out, and before that they had a 17 year history of failure. Beyond that, what are you gaining over the stock subframe bushings, which have a pretty proven out 200,000 mile service life.
IMO there's only two subframe bushing options that make sense:
1) stock
2) CMP solid (which raise the subframe, correctly the suspension geometry lost from lowering the car and/or adding reenforcement plates).
There's also these solid aluminum mounts that have removable spacers to account for plates. I have them in the garage waiting to go back in with the subframe.Originally posted by Obioban View Post^I agree with most of the above, but I'd skip the power flexsubframe bushings. Since 2017 isn't enough time to prove them out, and before that they had a 17 year history of failure. Beyond that, what are you gaining over the stock subframe bushings, which have a pretty proven out 200,000 mile service life.
1) stock
Configurable solid bushing set has the ability to correct the control arm angle and CV joint angle on lowered cars by raising the subframe up against the
haha same here! I had a similar if not the same gun lol.Originally posted by timmo View Post
I also ordered a 3M epoxy gun from eBay that came with a bunch of extra mixer tubes, which are also a definite must for this project.
Those look to be an e36 part...Originally posted by ZHPizza View Post
https://store.partsshopmax.com/shop/...is/E36SFR.html
Stock subframe bushings as a general rule do no last to 200k miles from what I've seen come through my shop. I do agree with you on your replacement bushing choices though, that is the shops preference as well.Originally posted by Obioban View PostBeyond that, what are you gaining over the stock subframe bushings, which have a pretty proven out 200,000 mile service life.
1) stock
Email to [email protected]
