Separating SSv1 slip fits.
    Anyone have any tricks to seperating the slip fits that connect the SSv1 headers to the ss section 1?
    2003.5 Titanium Silver / Black 6M/T (Gone)
    Feel like I'm an expert at this after taking them on and off a million times over the years 馃槀.. Couple tips:
    • Fully remove the allen bolts and wedge the split joint open with a screwdriver
    • Hit the joint with some heat and penetrating oil
    • Break them loose by rotating them up and down first
    • Once rotating, pull them out while rotating to get them off
    • When you re-install use some anti-seeze
      Ok great I will give that a try. Thank you! Also helps to know this struggle is normal and is doable.
        Just some penetrate and wiggle/rotate back and forth works.
        Applying some anti-seize to the header pipe ends will help with removal next time too. I put anti-seize on the bolts too as they're not iconel or really high quality.
        DD: /// 2011.5 Jerez/bamboo E90 M3 路 DCT 路 Slicktop 路 Instagram
        /// 2004 Silvergrey M3 路 Coupe 路 6spd 路 Slicktop 路 zero options
          A shot of WD-40 will work equally as well
            No, it doesn鈥檛. The function of WD-40 is to displace water. He doesn鈥檛 need to do that.
              Last few comments reminded me of a friend who a long time ago used wd40 to "lube" his chain on his time trial bike. Nono.
              Youtube DIYs and more
                Thanks Guys, got it off!
                Originally posted by robgill View Post
                [*]Fully remove the allen bolts and wedge the split joint open with a screwdriver
                This sparked an idea to flip the bolt to the threaded side and put a thin peice of metal in between. So when I tighten the bolt it now spreads the clamp.
