Eml light
  • Syfon
    Did you clean out the idle control valve with carby cleaner (i.e. throttle body cleaner)?
  • 0-60motorsports
    If you’ve replaced all the sensors could be wiring, throttle actuator, or maybe the ECU itself?
    Yeah they are looking over it. Car has 11k miles. Pisses me off when things like this happen on a mint vehicle lol
  • eacmen
  • 0-60motorsports
    If EML light is on you will have codes. Read them.
    I’ll say when this happened to me as you describe it was throttle pedal.
    You can also read live data to see if all the sensors as agree.
    Yeah on it. I forget what the codes were last time but they pointed to the tps under the intake and in front of it. I’ll update more when I read the codes
  • eacmen
    Hey All i have a EML light and car stalls when coming to a stop, all TPS are brand new and throttle pedal too, No obstructions to TB linkage etc. car is SMG. Any tips? Thanks
  • 0-60motorsports
    I believe Obioban posed q question regarding the id (code wise) of the respective tps in the last month or so.
    If the car tosses another eml at you, I think the post will come up on a search.
    Will have a look right now. All TPS sensors including Throttle Pedal are new.
  • FBloggs
  • 0-60motorsports
  • M3powerzz
    Thanks everyone for the help. I figured out what was wrong causing the stalling. The tube that goes into the intake manifold next to the dipstick wasn't in all the way.. Now the car is running good.
  • M3powerzz
    Yeah I will try to get it working. The stalling problem happen after I used the cruise control. iirc
  • eacmen
    My advice would be to get INPA working first instead of throwing parts at it.
  • M3powerzz
    Im going to change the clutch switch next.. 61319122700
    thats the correct part #?
  • M3powerzz
    Update , the problem is still happening. Stalling when coming to a stop.
  • M3powerzz
    Yeah I have inpa , but I get a error message when open it.
  • Arith2
    Originally posted by M3powerzz View Post
    How will I look at the PIDs?
    Well I guess it's fixed then ​​​​​
    You can use INPA to see info. Do you have it?
