The "Post Your Wheel Setup" Thread
    Sure, it’s a hamann rep:
    Car looks fantastic on E88s. Are you running a BBK up front? If so, how's the clearance on the ET25s?
      Thank you, I'm happy with them. I am running stock calipers with PFC08 pads for now. It looks like I have clearance to run BBK though. I plan on going with the Brembo Pista kit eventually.
        Here are a few of my car...
        Rays Gram Lights 57CR 18x9.5 +38 265/35 square. 12mm spacer front and rear. I ordered a larger rear spacer to push the rear out a bit more and a smaller front to remove some poke. Don't think I can go much less than a 10mm front spacer because the tire will rub on my suspensions height adjustable coil mount - if I dropped to a 6" spring instead of a 7" spring would give me another 10-15mm of space.
        Did you use any concentric hub? The wheel bore and our wheel hub size are different
          Stock e9x ZCP 359M wheels.
          19x9 - 245/35/19
          19x10 - 265/35/19
Name:
            19x9 - 245/35/19
            19x10 - 265/35/19
            Looks great, really does.
            My dude was so excited when he turned 16 and then he got a Hyundai (6 speed manual of course), lol. He is 18 now and when home from college we take turns driving the back roads in the sunshine, the best of times.
              19x9 - 245/35/19
              19x10 - 265/35/19
Name:
              What brakes are those? Do those wheels fit over them with no spacers?
                996s
                Front wheel is 9"et31. My 9"et30 arc8 needed a 5mm spacer minimum fwiw.
                  996s
                  I barely clear with a 3mm spacer up front 😂
                    That's awesome! My little guy loves this car and can't wait to take it over when I kick the bucket 🪣🫠
                      Click image for larger version  Name:	IMG_8986.jpg Views:	0 Size:	267.3 KB ID:	194805
                      Arc8R in Brushed clear, 18x10 ET25 275/35/18 square with 12mm spacer in the rear
                        Originally posted by Boost View Post
                        No good pics but I'm running 359Ms off an E9x M3. I like the concavity.
                        19x9 +31 (235/35/19)
                        19x10 +25 (265/30/19)
                        Need more rubber..
                        If I try another setup I'd like to pick up some TEs
                        Those are the rims I want as well. I like the look a little better then the E46 comp rims. Been keeping an eye out for a set.
                          I concur. Snag a set, you wont regret it
                          E46 M3 | C7 RS7
                            out of curiosity, why aren't you guys with the 359Ms running 245/275? I have the same width/offsets and those tire sizes with no rubbing, but might not be as low. I'm thinking about upgrading wheels to TA16, or some BBS option but I do really like the design of these. There's something about the radius of the fender arches and the radius of the concavity matching up that appeals to me. I just scrolled through this whole thread and was surprised I didn't see a single TA16 setup.
                            Apex EC7
                            18x9 +31 245
                            18x10 (or are they 10.5? I don't remember) +25 275
                            Click image for larger version  Name:	A6BEEAE9-4051-4F30-9333-0E62086FFE8F.jpg Views:	0 Size:	105.5 KB ID:	194860
                              Yeah that does look pretty great.
                                Nice, any close up shots? I considered these wheels, also looked into the polished finish but if I remember correctly the polished finish wheels were not offered in the same offsets as the others for some reason.
                                Nice wheels in any event!
