For sensor‘s like the intelligent Oil pressure/temp, diff temp sensor etc I would supply one or share the Part number that you can order it yourself.
I can source a solenoid (best way, because I can test the scaling) or you use your existing setup if you have a datasheet (with accurate information in it) for the sensor.
Beside Canbus, K-line values and intelligent oil sensor, the controller can handle up to 8 Analog inputs. All of them are 0-5V inputs. 4 of them can be used 2 Pin sensors to measure resistance (NTC/PTC like oil temp sensor).
But I don’t how far that huge amount of input makes sense on such a small display.
To switch pages, the display looks on the Can bus and waits for the conditions to match (Cruise control=off & Cruise control Button“+“ = is pressed). If the conditions match, the display switches to the next page. If you turn the car off and on later again it will go to the page that you had last time active (after a short splash screen). With CSL steering wheel you can switch to Z4 column cruise control to get the buttons and cruise control.
Other way to switch pages would be using one of the analog Inputs with a normal switch. E38/39 right wiper stalk have a additional Button like BC Button on the left, which is perfect for this.
