Nightmare following use of race pads on streets
    I've seen sparks from track pads when cold/new and being bedded. Doesn't necessarily indicate a problem in my experience.
      some race pads do emit a lot of sparks that are quite visible at night.
        Not just brake pads-- race parts are race parts for a reason. They always suck on the street.
          Like my AP calipers on my race car, they don't have rubber dust boots on the caliper pistons. Great on a race car, nothing to melt, but you won't want to drive around in winter without them.
            I completely fucked the finish on some ZE40s by leaving Hawk DTC60 brake dust on them for an extended period of time. Live and learn.
            But conversely, I have had PFC 08 pads on my E36 for literally like 7 years, and through 4 sets of wheels, none of which are ruined.
            '01 M3, Imola/black
              For those saying sparks are caused by a seized piston let me clarify: the sparks only happened during moderate to hard braking when brakes were cold
                What makes a track pad a track pad is the operating temp range. Lower temp pads (aka street pads) slow the car by being pressed against the rotor.
                A high temp race pads works differently. The reason why you HAVE to bed in track pads is because they require some pad material transfer to be evenly distributed on the friction surface. When a track pad gets up to temp, the pad works by essentially sticking to the rotor. If you can get a track pad up to temp on the street and touch the brakes, it WILL throw you forward and maybe do a face plant into the steering wheel.
                When track pads are cold, they are extremely abrasive. The pads are typically harder than the rotor which explains the sparks. When pressed against the rotor, the pads act like a grinder on the rotor. Pagids, PFC, Hawks...all do the same thing.
                Most of the rotor wear on a race car is from warming the pads up.
                The dust is hot rotor grindings that embeds into the paint. That explains the rotor wear. You probably also have a ton of dust embeded into the car paint behind the wheels. The reason why water makes it worse is once the grindings hit the wheel and embeds itself then it instantly cools. You might have a chance if you can keep the speeds up which will blow a lot of the dust off.
                  Those BMW engineers and OE suppliers are pretty damn smart, huh?
                    Thats crazy, do you guys think wheel ceramic coating is worth the trouble to make cleaning easier?
                      Just use RejeX. https://www.amazon.com/s?k=rejex&cri...je%2Caps%2C862
                        I primarily only use race pads specifically PFC 11s, on the street. I am not joking when I say 100,000 miles easily between multiple cars doing this. I have destroyed so many OE finished wheels, probably 4 sets of E38 Style 5s on my E28. Typically I find the zimmermans to be soft but they are meant for soft pads. I'll run them until they huge lip doesn't bother me too much.
                        The SSRs wheels I have seem to have a much better finish for that type of brake dust and clean off much easier and haven't gotten ruined even with all the miles being a moron and running race pads on the street. The Style 67s I ran on my E46 M3 were ruined in less then a month
                        Race pads on the street is really hard on the rotors, and dust very bad corrosive dust. Don't do it unless you are okay with that as well as dealing with operating temp not being ideal for morning stops.
                        IMO if you have 200tw, especially heat cycled ones the tires are cold and pads are cold. It all comes up pretty linearly in temp as a system so it's not a really an issue
                        Build Thread:
                          You know using race pads on the street is costing you a lot more $$$ than just swapping pads which I know you are perfectly capable of doing.
                            YOLO
                            - broke(n) person
                            Build Thread:
                              YOLO
                              - broke(n) person
                              Yeah but your overall costs are higher even if you factor in opportunity costs. Don't be lazy!
                                Can try a brand called copperhead, don’t dilute it and agitate it on there for 30sec then rinse. Apply it when the surface is dry and then follow up with a second application
