Nightmare following use of race pads on streets
    Roast me if you want . I did not know what I was doing and srapped a set of good ZCP style 163ms.
    I decided to take a road trip down to the tail of the dragon with my street-legal track car. I had recently installed PFC 331/332 (front/rear) on new Zimmerman blank rotors for a couple of track days. Life being busy, I did not get time to change the brake pads between my last track weekend and the road trip I had planned to the Tail of the Dragon with some friends. I thought to myself that this was not a big deal, and I would just be driving on highways with no braking and on the Dragon, something I considered to have things in common with track driving. It does not! The braking is light and sustained as opposed to intense and short, and the temperatures remain low.
    The aftermath is: I need new rotors; it ground several mms through the Zimmerman, and now I have deep grooves and a high lip on the rotor. But that's not too much of a big deal: rotors are relatively cheap. The worst part is it left a coating on my ZCP Style 163m wheels like I would have done a black matte powder coating, and nothing I tried seems to do anything: several rounds of wheel cleaner and iron remover, paint thinner (I thought it might soften the adhesive in the pad dust that makes it stick to the wheel). I took a Scotch-Brite pad and scrubbed the baked-in brake dust (as a last resort, as this could scratch the finish of the wheel, but I'm at a point where that's not something I'm so much concerned about anymore).
    Anyways here are the photos of the aftermath. So don't use race pads on streets. And if anyone has advice on how to get rid of that coating, let me know. Also, why does this not happen on tracks? Why are the pads eating through the rotor when cold but not when hot? I suspect it's related to the transfer of material to the rotor, which has a protective effect. If you are a brake expert and know the answer I am very curious.
    Click image for larger version  Name:	IMG_5903 Medium.jpg Views:	0 Size:	103.0 KB ID:	571750
    Click image for larger version  Name:	IMG_5904.jpg Views:	0 Size:	154.8 KB ID:	571752
    Click image for larger version  Name:	IMG_5901.jpg Views:	0 Size:	217.2 KB ID:	571749
    Click image for larger version  Name:	8684F10F-107C-4D1C-A24C-AE65F7E032EB.jpg Views:	0 Size:	115.6 KB ID:	571753
    Click image for larger version  Name:	660E64DB-458E-44F2-BC7C-E287342C224E.jpg Views:	0 Size:	175.6 KB ID:	571747
    Click image for larger version  Name:	IMG_5900 Medium.jpg Views:	0 Size:	129.3 KB ID:	571754
    Click image for larger version  Name:	8684F10F-107C-4D1C-A24C-AE65F7E032EB.jpg Views:	0 Size:	115.6 KB ID:	571746
    Try Koch Chemie reactive rust remover
    2004 Dinan S3-R M3
    2023 X3M Competition
      Track pads are abrasive if they are not up to temp. When this happens, it will remove any transfer layer and will increase rotor wear. And then there is the dust which can damage the finish on your wheels. If clay bar or that nasty, color changing, heavy duty wheel cleaner isn't removing pad material from the wheel finish, the wheel will probably need to be refinished.
      It would be a good idea to have another set of wheels for track use. If the finish gets ruined or they get damaged, it won't matter.
        Gat. Dayum.
          Some track pad compounds destroy wheels, Sorry OP
          I've had this happen in the past with DTC60s and the dust permanently etched itself into the finish. PFC08s seem to be a lot friendlier to wheels.
            I do have one, but for the road trip I put my street tires and I'm glad I did (except for the problem above), as it rained and going with the track set with the Re71rs' would not have been ideal.
            Oh, and telling the story, I forgot to say: there were sparks coming out of my wheels when braking moderately hard during the trip. Hell. I knew it wasn't "recommended" to drive on track pads on the streets. I didn't know it was absolutely one of the worst things to do and the consequences would be over 1000 worth of damage.
            Here's one more image of my wheel during the trip, when I still thought I would just need to wipe down the dust and it would be fine: Click image for larger version
              Thanks for the tip, so you think it's a better/stronger product than the one that I use that:
              - also turns purple
              - advertises the same properties (removes baked in brake dust)
              My gut feeling is that restoration is my only route.
              I am also skeptical about what a clay bar would achieve. That crust is thick and hard, and even a fingernail can't get through it.
                The previous owner of my original IB car did the same thing. When I bought the car it had 4-pot Brembo 355 GTs on the front (with race pads), and the 355x32mm rotors measured 355x22mm haha. David from zeckhausen.com was astounded when I showed him pictures; he said he's never seen a rotor that badly worn. So yeah, don't run race pads on a not race car.
                I also couldn't get the dust off the 163m wheels and ended up having them refinished
                Before:
                After:
                  Wow
                  That is impressive (sorry you had to experience that)
                  It really depends on what track pads you run, not all track pads will do that.
                  PFC08, Pagid RSL29, Carbotechs, to name a few I have personally experienced, have friendly dust that easily comes off with a wheel cleaner & pressure washer.
                    Man I appreciate you sharing.
                    ///02 E46 M3 6MT CB over Imola, B16 PSS10 (Daily) Apex FL-5
                    ///05 E46 M3 6MT TiAg over Imola, Ohlins R/T, Apex ML-10
                    09 E93 N54 6MT, Sapphire Black over Dove, 313's (R.I.P) ​
                      I've not swapped out my track pads on my e92 for years, since 2019 or so, been trough a few sets of PFCs 08s and 331/332 and I've never had an issue like that. I have some ZCP wheels that were powdercoated a dark gray and the pad dust mildly embedded in the clear giving them a slight brownish hue but is polished off very easily. My track wheels are anthracite EC-7s which clean up surprisingly well. Were you down to the baking plate? PFC are know for being very rotor friendly, especially at temp.
                        This happens on wet, hot wheels. PFC-01 compound used to do this on a wet track. No hot and wet.
                        Sparks mean you have a problem. Go find it. Don't ignore it. I'd first look at caliper piston seals - then move on.
                          Curious of why the piston seal related issue caused the flying sparks?
                            I didn't say that it caused it.
                            Sparks out of the wheel obviously means metal against metal. With abnormal wear on a new rotor, I think an early check should investigate whether the caliper piston is freely withdrawing after braking - or allowing the pad to continue to press (albeit lightly) against the rotor. A worn/failing caliper piston seal can cause slow/problematic piston withdrawal.
                              Understood.
                              A dragged or seized piston is very easy to detect: at a slightly incline road or driveway a normal car in neutral should roll freely, and if not then piston is seized.
