Everything about Fat Cat Motorsport Suspension
    Pulling the trigger, finally. Can't believe I'm a year behind!
    Got some Bilstein PSS - yes non-M but they are non-adjustable monotubes. They physically fit although I am sure the springs and actual valving is a bit different. Jalad said I may need some different rods - $100? This set of coilovers is $1239, H&R are $1400. Now I need to get my lazy ass to the track, ballast the car up to 3000lbs, corner balance, and then send the results to Jalad.
      Was the relationship pretty linear for the motion ratios? Care to share the plots? Curious as the e46 has an instant center basically at the diff which makes for lots of lateral displacement throughout the travel. No real migration of the rear roll center but a whole lot of jacking sadly.
      Since you know the instant center location, do you have the suspension hardpoint location coordinates? A friend is wanting to dive deeper into the kinematics and dynamics of my setup.
      2003.5 Carbon Black ///M3 @_weaponM
      MCS | Supersprint | CAE | TC Design | Momo | Schroth | Rogue | Turner | Bimmerworld | Vorshlag | Hyperco | AKG
        Small world, a respected local shop owner was just telling me about Fat Cat. I've lots to learn from this thread.
          Uhhh... aren't the non-M missing the mounting tab for sway link?
            No. The TC Klines on the car now were on my 330Ci. I pulled the entire assembly out of the 330Ci and put it in the M3.
              Took awhile, got the FCM dampers installed. Running 400lb/850lb springs which puts me at 2.25hz front and 2.47hz rear for flat ride. Ground control front bar, no rear bar.
              I am having an issue getting enough camber even with Vorshlag camber plates on the right front. My car has always tended to have less camber on the right side but now its a 2 degree difference at max camber. I had a nasty off Jan 2025 where I damaged the right-side control arm ball joint and the FCAB. Then had a right-side wheel bearing go bad. I'm thinking I have a bent knuckle. But I could get to -4.25 with the TC Klines. I'm sure the knuckle is bent, is it a little or a lot? .
              Ran this past weekend at MSR Houston (shit surface) with 3 heat cycle goodyear 3Rs. Alignment was set at -3.5 degrees of camber in the front and no other changes - zero front toe, -3.5 camber in the rear with 1mm of toe in. The bad news, the left front wheel speed sensor wire got pinched, ABS failed and plowed straight through the grass. I think that knocked my front toe out of whack.
              The good news. As advertised the car takes bumps extremely well. Drove 25 laps in back-to-back sessions and felt pretty good afterwards. Normally I'd be worn out. At MSR Houston, I have issues with my foot coming off the gas from bumps, no more of that.
              I did an alignment afterwards, the front tires were toed in - probably from going off. That happened on the 3rd lap which I think this affected lots of things. Not sure I have any conclusions on lap times at this point.
              The tires took a full 2 laps to come in. The ambient temps were in the high 50's, low 60s. This may be an issue for time trials. The rear end especially but with the front tires toed in...makes sense.
              Best lap was a 1:41.3, virtual best was a 1:41.1. My PR is a 1:40.5. My driving was an issue. It is hard to be confident in the brakes when you plow straight off track at 125 mph and flat spot two tires. There is potential here. I also didn't sleep great the night before so this was not my best driving. I did get a lot of laps in to get a feel for the car.
              There was low speed understeer. Not terminal I'm about to plow into a wall head on understeer. Far more subtle. I missed quite a few apexes by half a car width that I normally don't miss. I don't miss many apexes by that much. Maybe 1 or 2 over a weekend. Probably track conditions, it was hard to get the rear end to hook up in some spots - others did report similar grip issues.
              I know with this track, it comes down to trail braking. I could find an easy second. And I wasn't REALLY pushing.
              I wanted to be faster out of the box. Can't make any lap time conclusions yet. I will say that the car in fact rides much better and absorbs bumps and curbs really well. Need to address the camber issue...nothing a grinder can't fix. Might with in PCA Dec 5-6. Sucks because my company holiday party is the Fri before - free beer, mid-shelf old fashioneds, decent food, and night out with the wife. May not be able to get drunk for free this year...depends on how committed I am. Decisions...lol
                bigjae46 how do you have that front bar setup? (I have same bar)
                  Your TCK strut is probably bent to match your bent knuckle to a degree. I could see how hitting a curb would create a bend combo like that. Try taking a straight edge to the old strut, it’s most likely to bend right above where the knuckle clamps it based on my FEA results.
                    It is on the softer side.
                    Good idea...didn't think of that. Will do!
                      - zero front toe
                      Try a little bit of front toe out.
                        I suspect that zero toe will be fine with more negative camber.
                          Agreed with Bry5on Stick your thumb or finger between the strut and rim and measure the difference. IF there is a notable difference and you still had the TCs I'd say its the strut, but since you've changed that variable the only other cause is the spindle.
                          You might also consider replaced that RF inner and outer tie rod. If you had a hit hard enough to tear up the strut I would be worried the tie rod is damaged too.
                          Looking forward to your FCM review with the car sorted.
                          Email to [email protected]
                            I also recently went for an accidental drive on the grass at ~110mph (thunderbolt turn 3, for anyone local). Didn't really ponder it at the time, but the FCMs did do exceptionally well with the unplanned rally stage-- was able to drive it back onto the track and didn't even feel compelled to slow below ~60mph.
                            The entire experience was surprisingly undramatic, for being easily the fastest I've been offroad.
                              I put a straight edge on the TC Klines, straight as an arrow. The off was Jan 2025. Replaced the FCAB and control arm. Then Mar 2026, the wheel bearing started making noise...a relatively new one that was maybe 2 years old?
                              GSR makes a weld on reinforcement plate or I can make my own if I end up cutting into the tower...which I'm considering. ​
                              Here is the off from Jan 2025.
                              I also recently went for an accidental drive on the grass at ~110mph (thunderbolt turn 3, for anyone local). Didn't really ponder it at the time, but the FCMs did do exceptional well with the unplanned rally stage-- was able to drive it back onto the track and didn't even feel compelled to slow below ~60mph.
                              It was incredibly smooth going through the grass. Felt like I was gliding, normally going off is very bumpy and teeth chattering. Didn't think about it until now. 🤣
