Combine two OEM Section 1's?
    Quick Question:
    Instead of adding an AR20/25 to the OEM section 1, will a second OEM section 1 resonated pipe line up? I'm about to pick up a used set of OEM section 1 pipes with the intent of combining the resonated pipe to my oem section 1, and figured I'd ask before committing to buy.
    Thanks
    ’03 Oxford Green M3 (Turbo’d)
    To make a rasp eliminator right? Yeah it should work, I believe it's been done before. Let us know
      Thank you!
      picking it up tomorrow, I’ll keep y’all updated
        Yeah it works, I've got this on my car right now. There's a bracket welded between the two pipes that you have to cut off before you can combine them. It's a bit tight, but they do fit.
          A buddy of mine recently picked up a spare section 1 to add the 2nd resonator to his section 1. Removed a lot of rasp from his setup and was very cost effective.
            The results can be viewed here:
              Running that setup on my car. Only issue I had was a harmonic rattle at idle from the 2 individual pipes vibrating against each other. Had a welder buddy tig a little bracket between the sections to stabilize them and no issues since. Rattle was possibly a little more pronounced on mine because I'm also running headers.
                https://www.youtube.com/watch?v=Iy0at2f4YPc
                great video! thanks
                  That same issue was mentioned in the video Mike RT4 posted. This could be a great opportunity for me to learn to weld (or if all else fails, take it to a shop to weld the bracket)
                    I'm also running a pair of resonated section 1 pipes, along with a supersprint resonated section 2 and dinan section 3. I had a similar rattle issue slightly above idle which I resolved by welding a bracket between the two pipes. Sounds great, minimal rasp, sporty, not too loud.
