E46 Dashboard Monitor
    I'm currently prototyping a dual display, dual UCB C PD module in place of the E46 ashtray. The module can communicate with either or all of these buses - K-Line, I-Bus, CANBUS. It can also do datalogging to an SD card if installed. Currently in development stage focussed on the MSS54HP dme. I'll keep adding support for more ECUs in furture.
    I'll post updates on the progress going forward - just started 3 days ago.
    Feel free to follow my work. Thank you all for the support and any feedback.
    2026/11/25 update (v1.7)
    Some photos of actual hardware while bench testing in DEMO mode.
    Now the USB C port can be monitored for power delivery output.
    Also a second USB C port is available. This can be used to download the datalogs without having to remove the sd card from the slot. The port also acts as the firmware programming port. This will be routed next to the existing USB C port in an upcoming board revision.
    Click image for larger version  Name:	image.png Views:	10 Size:	952.9 KB ID:	616715
    Click image for larger version  Name:	image.png Views:	10 Size:	932.3 KB ID:	616716
    Click image for larger version  Name:	image.png Views:	10 Size:	910.7 KB ID:	616717
    Click image for larger version  Name:	image.png Views:	10 Size:	919.0 KB ID:	616718​​​
    Curious of why the board needs to have 24v output using DC/DC regulator?
      For usb PD up to 60W x 2.
        Some screen mockups. Will post some real photos soon. Someone over reddit suggested that I incorporate the amber theme on OEM bmw displays.
          Currently implementing CSV data logging to connected SD card if one is available. It can be turned on and off with a second button.
            Very cool. What microcontroller did you pick for this? Those two rows of through holes make me think ESP32-S3.
              ESP32-S3 - yes.
                I made a launcher for e46 which I built a esp32 can bus pcb. This would be cool to integrate.
                  Rock on! Cool AF
                  Sent from my Pixel 9 Pro using Tapatalk
                    retromuz - i'd definitely be interested in buying this, this fits in the ashtray slot under the HVAC controls? Love the vert image on bootup (saw the video on reddit)
                    |06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|AutoSolutions SSK|​Bi-LED|​TMS CSL Box|Megan headers|Mullet Tune|Bryson Air Inlet|​E86 Triangulation Brace|Bryson Fender Braces|​Dusan Rear X Brace and Topside​​|​OEM Section 1, 2, 3|200 Cell Cats|Bilstein B12|712 yellow tag|​
                      siamkazi Thanks. This one fits in the ashtray beside the cigarette ligher socket.
                      I'm doing the finishing touches on the PCB at the moment. Next step is getting a housing 3D printed. The ashtray is different on LHD vs RHD cars. I'll be designing for both. Will keep you updated in here.
                      Recently added features: Video and Photo playback.
                        Awesome, i was building this out then came across your thread. Keep us updated.
