E46 Dashboard Monitor
    I'm currently prototyping a dual display, dual UCB C PD module in place of the E46 ashtray. The module can communicate with either or all of these buses - K-Line, I-Bus, CANBUS. It can also do datalogging to an SD card if installed. Currently in development stage focussed on the MSS54HP dme. I'll keep adding support for more ECUs in furture.
    I'll post updates on the progress going forward - just started 3 days ago.
    Feel free to follow my work. Thank you all for the support and any feedback.
    2026/11/12 Update (V1.1)
    Found the first setup of 2 separate displays being too small to see much. Went for a larger single IPS 3.99 inch 400x960 display. The problem was that this display did not support the slow SPI addressing. It needed full RGB. So had to drop the ESP32-S3 and move to ESP32-P4. So it's a brand new 4 layer board layout that embeds everything in one. Also the benefits are that now it has onboard 60W USB-C PD charger port, easily accessible SD slot better vieweing angles etc.
    PCB sent to production - waiting for them to arrive.
    Click image for larger version  Name:	image.png Views:	0 Size:	370.2 KB ID:	615140
    Click image for larger version  Name:	image.png Views:	0 Size:	429.0 KB ID:	615141​​
    Click image for larger version  Name:	image.png Views:	147 Size:	65.6 KB ID:	614727​
    V1.0
    Click image for larger version  Name:	Screenshot 2026-11-06 at 18.57.25.png Views:	29 Size:	352.6 KB ID:	614694
    Click image for larger version  Name:	Screenshot 2026-11-06 at 18.57.08.png Views:	29 Size:	308.0 KB ID:	614695​​
    Curious of why the board needs to have 24v output using DC/DC regulator?
      For usb PD up to 60W x 2.
        Some screen mockups. Will post some real photos soon. Someone over reddit suggested that I incorporate the amber theme on OEM bmw displays.
          Currently implementing CSV data logging to connected SD card if one is available. It can be turned on and off with a second button.
            Very cool. What microcontroller did you pick for this? Those two rows of through holes make me think ESP32-S3.
              ESP32-S3 - yes.
                I made a launcher for e46 which I built a esp32 can bus pcb. This would be cool to integrate.
                  Rock on! Cool AF
                  Sent from my Pixel 9 Pro using Tapatalk
