Originally posted by 0-60motorsports
HELP!--Shuddering When Under Heavy Throttle (Part 2)
It's not a common thing but DMEs definitely do bad. One pin on one microchip could have just a little bit of corrosion. I'd love to see an update on what is found when you get it checked out.This is my Unbuild Journal and why we need an oil thread
Yeah i will update the thread or sure with my findings or just create a new thread linking the OPs thread to it.Originally posted by Arith2 View Post
I had a DME go bad on the M3 wagon. Symptoms were poor drivability and random codes. Not common, but it does happen.
Possibly related: I ignored a DME cooling fan failure for a couple of months before it failed. So.. likely user error.
I had something similar (shuddering at high load/throttle, no CELs, CSL airbox and DME) and found it was due to a leaking vacuum reference line for the fuel pressure regulator. It's a small rubber hose piece at the end of the air pipe on top of the engine toward the firewall.
the part: https://www.turnermotorsport.com/p-3...uine-bmw-part/
I changed it out and the shuddering went away."your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
I replaced that too and it didn’t fix the issue. In the end the original dme converted to HP did the trick.Originally posted by zzyzx85 View PostI had something similar (shuddering at high load/throttle, no CELs, CSL airbox and DME) and found it was due to a leaking vacuum reference line for the fuel pressure regulator. It's a small rubber hose piece at the end of the air pipe on top of the engine toward the firewall.
Alright so I am going to replace:
1) Vacuum Hose
2) Check for shadow codes (none have been thrown in the part but I might as well)
3) See if I can get it tuned out
4) Buy another DME and get it converted again.
Let me know if y’all run across a fix. It is bugging me.
Sent from my iPhone using Tapatalk2006 ///M3 6MT Coupe Jet Black Track Car
