Originally posted by 0-60motorsports
HELP!--Shuddering When Under Heavy Throttle (Part 2)
It's not a common thing but DMEs definitely do bad. One pin on one microchip could have just a little bit of corrosion. I'd love to see an update on what is found when you get it checked out.
I had a DME go bad on the M3 wagon. Symptoms were poor drivability and random codes. Not common, but it does happen.
Possibly related: I ignored a DME cooling fan failure for a couple of months before it failed. So.. likely user error.
I had something similar (shuddering at high load/throttle, no CELs, CSL airbox and DME) and found it was due to a leaking vacuum reference line for the fuel pressure regulator. It's a small rubber hose piece at the end of the air pipe on top of the engine toward the firewall.
the part: https://www.turnermotorsport.com/p-3...uine-bmw-part/
I changed it out and the shuddering went away."your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
Originally posted by zzyzx85 View PostI had something similar (shuddering at high load/throttle, no CELs, CSL airbox and DME) and found it was due to a leaking vacuum reference line for the fuel pressure regulator. It's a small rubber hose piece at the end of the air pipe on top of the engine toward the firewall.
Alright so I am going to replace:
1) Vacuum Hose
2) Check for shadow codes (none have been thrown in the part but I might as well)
3) See if I can get it tuned out
4) Buy another DME and get it converted again.
Let me know if y’all run across a fix. It is bugging me.
Sent from my iPhone using Tapatalk2006 ///M3 6MT Coupe Jet Black Track Car
