The thing with epoxy is that the quality of the job is highly dependent on bond gaps. Perhaps since the vince skins are pre-formed to the RACP along with rivets, that isn't an issue. But otherwise, without rivets and plates closely adhering to the surface of the RACP, I would weld it
Got my vincebar today
Unfortunately I was unable to weigh the candies before my daughter smashed on them but 4oz seems about right.Originally posted by sapote View Post
What's the total weight?
The vincebar weighs in at 6.6 lbs without the accompanying bolts and gusset cups.
No, the Vincebar is standalone and the cups aren't large enough to add an x brace. If you want to do all that, then I'd order a kit from SME. He makes a weld in brace similar to the Vincebar and will reduce the height of an accompanying x brace to ensure fitment.Originally posted by ///m325i View PostDoes anyone know if the vincebar works with those aftermarket rear x brace bars? I figured doing the vincebar, x brace and reinforcement plates underneath would be ideal.
SME (Specialised Motorsport Engineering) have designed this brace to be the lightest and strongest on the market, and unlike other available braces it truly strengthens the E46’s weak rear axle carrier panel. Precision fabricated from Chromoly, this brace only weighs 3kg and is a simple install – no welding required, just a small amount of drilling to allow access to the RACP from above. Kit comes complete with drilling jig and instructions. New bolts then drop all the way through to the subframe for a truly braced outcome unlike rival products which simply bolt to the skin above the RACP. Fitting instructions can be found on the previous page to give more insight into what is involved. The SME E46 RACP Brace strengthens the rear end of the E46 BMW, which is a known weakpoint. Made from Chromoly material and supplied in one piece, the brace weighs just 3KG!
Definitely a belt & suspenders approach
You should look into CMP products. https://cmpautoengineering.com/collections/allOriginally posted by ///m325i View PostDoes anyone know if the vincebar works with those aftermarket rear x brace bars? I figured doing the vincebar, x brace and reinforcement plates underneath would be ideal.
And the stealth version is 5.5 lbs.Originally posted by Mspir3d View PostThe vincebar weighs in at 6.6 lbs without the accompanying bolts and gusset cups.
DD: /// 2011.5 Jerez/bamboo E90 M3 路 DCT 路 Slicktop 路 Instagram
/// 2004 Silvergrey M3 路 Coupe 路 6spd 路 Slicktop 路 zero options
Braces that bolt through the rear subframe mounting points don't need the subframe dropped afaik. Support the subframe or do one side at a time.DD: /// 2011.5 Jerez/bamboo E90 M3 路 DCT 路 Slicktop 路 Instagram
I guess it could. You'd just need a long drill bit and a long tap. Actually, I think vince sells a kit with the longer tools.Originally posted by dl.m3 View PostAnybody know if this can be installed without dropping the entire subframe? Really dont wanna do that on jackstands.
Have redish plates welded already, always wanted to add a top bar.
Sent from my HD1905 using Tapatalk2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I installed a mason bar with the subframe on the car. Just dont let the long boy drill bit walk and damage the subframe threads.Originally posted by heinzboehmer View Post
Mason just uses threaded rod that matches the subframe bolt and secures either end with a lock nut and washer. There is an option to tap all the way through the subframe into the floor but all the installs i've seen don't actually do it because of the tooling required.
This is the drill bit I got:
DEWALT DW1606 1/4-Inch by 12-Inch... https://www.amazon.com/dp/B00004RGYN...p_mob_ap_share
Ah right. The version I've got has the front stud in two parts, so basically a long threaded rod and a threaded washer. I supposed you could drop the subframe just enough to remove the factory studs and install the new ones.Originally posted by dl.m3 View PostI suppose the rears can be done exactly like a Mason bar, drilling upwards.
But the fronts (gusset cups) I'm not sure since there's a threaded stud that needs to go onto the body before the subframe bushing. Hmmm
But honestly, dropping the subframe is not that big of a deal. I've done it on jack stands twice with nothing more than some cheap moving dollies, a jack, and different wood bits to stick in between the jack and subframe to keep it parallel to the ground. Took about 3-4 hours each time.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
