Rear camber issue after subframe reinforcement
    Hoping someone can help me figure this issue out...
    I recently installed vincebar, vinceskinz, solid rear bushing, and monoball RTABs to solidfy the rear of my '02 daily. I took it in for an alignment, but the shop said they were unable to get the rear camber into spec. Factory spec is -2.0 to -1.5 degrees and they said the adjustment was maxed out at +1.5 degrees which is 3 degrees outside of the range on both sides.
    Has anybody had an issue with too much positive camber after dropping the subframe and/or doing a reinforcement? I'm thinking I could install adjustable camber arms, but not sure if they would able to cover a gap that large. Thanks in advance!
    adjustable arms will give enough adjustment.the stock arms are prone to bending which could be your case.it was with me.
      When I first got my car the rtab brackets were wrong installed. They need to be inside the pocket. Maybe thats the case.
      2003 AW/BLK 6MT - Instagram
        When you say solid rear bushings do you mean CMP solid subframe bushings? If so, those raise the subframe a bit in an attempt to correct the roll center geometry that gets messed up when you lower the car. You'll need camber arms if you want to stay at stock height and want to get the rear camber back in spec.
          looooool how did whoever did that get that wrong?!
            Well, I done goofed. Rushing to put it back together and put the rtab brackets in upside down lol. That’s a big hit to the pride. Thanks for the help Zekarus
              that was exactly my reaction to when i found out. subframe was reinforced from Import Performance INC in Raleigh, NC. so I guess they fu**ed this up. and they used a sealer that doesn't dries. so i have to drop the subframe this winter to do their job again.
                This was exactly what happened to me also.
