  • Gt4
    Nice wheels! what are the specs?
    19x9.5 et32 & 19x10.5 et19
    Can't wait to install them, should be pretty tight with 245/35/19 & 275/30/19
  • elrichmeister
    Just got my BBS RS2 back from the welding shop. Decided to weld lips and barrels together instead of the hidden hardware finally. Next step: mounting tires on them
  • Gt4
  • 9kracing
    Very nice!
    You ever decide to sell those, PM me
  • M3LSB.Gab
    Dope, what are the specs on these?
    BBS RS2 714/700 – 3-Piece 19” Stepped Specs:
    • Bolt pattern: 5x120
    • Sizes: 19x9 ET25 (Front) / 19x10.5 ET30 (Rear)
    • Professionally converted to 3-piece using hidden hardware
  • Gt4
    Just got Ohlins Dedicated track coilovers for my LSB M3
  • 0-60motorsports
    Originally posted by M3LSB.Gab View Post
    I found a local set of BBS RSII. Will be polising them, installing PS4S tires and waiting to find a clean E46 M3
    Beautiful
  • 9kracing
  • siamkazi
    Rear headrest go-pro bracket for POV on these amazing fall evenings (used an older action cam to test):
    Click image for larger version  Name:	Screenshot_20251104-125125_Instagram.jpg Views:	0 Size:	54.8 KB ID:	325486Click image for larger version  Name:	Screenshot_20251104_140820.jpg Views:	0 Size:	145.3 KB ID:	325487
  • M3LSB.Gab
  • maupineda
    Made some progress. I applied the primer, I mixed it as a surfacer. Came out good with very few dust particles. Not concerned at this point as it needs to be sanded to make it flat. The area I repaired came out ok. Not perfect, but I think I can level the primer just enough to make it invisible once colored and cleared
    And this is the side I repaired.
    Sanded the primer on the repaired area and super happy with the result, I cannot tell where the damage was. I just need to finesse the edge, it may not be perfect but for the untrained eye, nothing happened there
  • 1000hp
    Subframe (plates + topside brace)
    RTABS
    Diff bushings
    Pinion and axle seals
    Rear ball joints
    Rear adjustable LCAs
    Front control arm bushings
    P/S pressure hose
    P/S pressure regulator shims (added 2)
    Poly steering shaft flex coupler
    Megan headers
    (Been dicking with it for a few weekends but wrapped it all up today).
  • 6speedS54
    Replaced detents on top of the transmission, roller with a spring on the side behind the GPS, and shifter rod seal. Guess I now know why the shifter was popping out intermittently 😂😂 The shifting feel is much tighter now than before.
  • PSUEng
    Thought I'd get one of these, seemed to be a good deal.
Name:	Screenshot 2025-11-01 at 6.08.31 PM.png
  • zzyzx85
    Inspected the parts I bought for it.
    Freaky Parts front Brembos:
    Porsche 996 rear Brembos:
ID:	325120 Click image for larger version
ID:	325121 Click image for larger version
