    Finally got my front seats finished to complete the interior...also some new rare kicks!
    Long story short...I was able to source a complete ZHP coupe alcantara/laser cloth interior and extra rear seats for additional fabric. I ripped the center cloth fabric off the seats and used them to reupholster the Recaro PPs. The Laser cloth (G7AT) material appears to be the exact same as found on the M3 CSL labeled ADAT - Anthracite Reflex cloth which I thought was interesting.
    Recaro Pole Position Carbon ABE w/ Anthracite Alcantara and Laser Cloth (G7AT) and a very rare set of 18" BBS FI wheels:
    absolutely gorgeous!
      Holy moly
        I continued my search for a set of 219m wheels in good shape, and went down the rabbit hole of suspension options! I hope I find my way back..
        2003.5 Mystic/Blk - El Diablo, Coilovers, CMP Reinforcement, 2x OE Res. Section 1. - The new project
        '95 M3 - 800whp, 2jz, 6-speed, MS3x, Tilton, Large Case, etc.. - gone.
        '11 X5d - Potholed, Tuned daily rig
          After a fistfight with the garage door, had to learn myself how to do bodywork.
          Click image for larger version  Name:	IMG_2484.jpg Views:	260 Size:	94.2 KB ID:	321951
          Click image for larger version  Name:	IMG_2606.jpg Views:	263 Size:	137.8 KB ID:	321950
          Click image for larger version  Name:	IMG_2612.jpg Views:	259 Size:	72.9 KB ID:	321948
          Click image for larger version  Name:	IMG_2613.jpg Views:	268 Size:	182.0 KB ID:	321949
          Made some progress. I applied the primer, I mixed it as a surfacer. Came out good with very few dust particles. Not concerned at this point as it needs to be sanded to make it flat. The area I repaired came out ok. Not perfect, but I think I can level the primer just enough to make it invisible once colored and cleared
          And this is the side I repaired.
            Cut the exhaust manifold heat shield into two for future header swapping / removal. I left a quarter-inch gap between the two parts so that they would slip in and out easier.
            First 2-hour heat cycle with Supersprint stepped V1s and they’re already bronze!
              Ordered an Eventuri carbon airbox 🫠
                an absolute must!!!
                  those seats are fireeeee
                    Today I finally adjusted my ride height after years of ownership. I've got the Bilsten PSS10s, went up 3 full turns in the front which took the height from about 13 1/8" to 13 1/2". Didn't touch the rear, but it's about 14 1/8", which apparently should probably come down a bit from what I've read lately.
                    I only went for a short drive, but the ride quality and comfort over bumps and dips seemed much improved. I should have done this a long time ago, I suspect I've been hitting the bump stops fairly often.
                      Inspected the parts I bought for it.
                      Freaky Parts front Brembos:
                      Porsche 996 rear Brembos:
ID:	325120 Click image for larger version
ID:	325121 Click image for larger version
                      2007 GX470
                      build/journal
                      ig: @zzyzx85
                        Thought I'd get one of these, seemed to be a good deal.
Name:	Screenshot 2025-11-01 at 6.08.31 PM.png
                          Replaced detents on top of the transmission, roller with a spring on the side behind the GPS, and shifter rod seal. Guess I now know why the shifter was popping out intermittently 😂😂 The shifting feel is much tighter now than before.
                            Subframe (plates + topside brace)
                            RTABS
                            Diff bushings
                            Pinion and axle seals
                            Rear ball joints
                            Rear adjustable LCAs
                            Front control arm bushings
                            P/S pressure hose
                            P/S pressure regulator shims (added 2)
                            Poly steering shaft flex coupler
                            Megan headers
                            (Been dicking with it for a few weekends but wrapped it all up today).
                              Sanded the primer on the repaired area and super happy with the result, I cannot tell where the damage was. I just need to finesse the edge, it may not be perfect but for the untrained eye, nothing happened there
                                I found a local set of BBS RSII. Will be polising them, installing PS4S tires and waiting to find a clean E46 M3
                                Instagram : @gc.m3zcp
                                2023 M3C Xdrive British Racing Green
                                2009 M3 Alpine White DCT
                                2005 M3 ZCP Slicktop Alpine White 6 speed
