    Holy moly
      I continued my search for a set of 219m wheels in good shape, and went down the rabbit hole of suspension options! I hope I find my way back..
      2003.5 Mystic/Blk - El Diablo, Coilovers, CMP Reinforcement, 2x OE Res. Section 1. - The new project
      '95 M3 - 800whp, 2jz, 6-speed, MS3x, Tilton, Large Case, etc.. - gone.
      '11 X5d - Potholed, Tuned daily rig
        After a fistfight with the garage door, had to learn myself how to do bodywork.
        Click image for larger version  Name:	IMG_2484.jpg Views:	260 Size:	94.2 KB ID:	321951
        Click image for larger version  Name:	IMG_2606.jpg Views:	263 Size:	137.8 KB ID:	321950
        Click image for larger version  Name:	IMG_2612.jpg Views:	259 Size:	72.9 KB ID:	321948
        Click image for larger version  Name:	IMG_2613.jpg Views:	268 Size:	182.0 KB ID:	321949
        Made some progress. I applied the primer, I mixed it as a surfacer. Came out good with very few dust particles. Not concerned at this point as it needs to be sanded to make it flat. The area I repaired came out ok. Not perfect, but I think I can level the primer just enough to make it invisible once colored and cleared
        And this is the side I repaired.
          Cut the exhaust manifold heat shield into two for future header swapping / removal. I left a quarter-inch gap between the two parts so that they would slip in and out easier.
          First 2-hour heat cycle with Supersprint stepped V1s and they’re already bronze!
            Ordered an Eventuri carbon airbox 🫠
              an absolute must!!!
                Finally got my front seats finished to complete the interior...also some new rare kicks!
                Long story short...I was able to source a complete ZHP coupe alcantara/laser cloth interior and extra rear seats for additional fabric. I ripped the center cloth fabric off the seats and used them to reupholster the Recaro PPs. The Laser cloth (G7AT) material appears to be the exact same as found on the M3 CSL labeled ADAT - Anthracite Reflex cloth which I thought was interesting.
                Recaro Pole Position Carbon ABE w/ Anthracite Alcantara and Laser Cloth (G7AT) and a very rare set of 18" BBS FI wheels:
                those seats are fireeeee
                  Today I finally adjusted my ride height after years of ownership. I've got the Bilsten PSS10s, went up 3 full turns in the front which took the height from about 13 1/8" to 13 1/2". Didn't touch the rear, but it's about 14 1/8", which apparently should probably come down a bit from what I've read lately.
                  I only went for a short drive, but the ride quality and comfort over bumps and dips seemed much improved. I should have done this a long time ago, I suspect I've been hitting the bump stops fairly often.
                    Inspected the parts I bought for it.
                    Freaky Parts front Brembos:
                    Porsche 996 rear Brembos:
ID:	325120 Click image for larger version
ID:	325121 Click image for larger version
                    2007 GX470
                    build/journal
                    ig: @zzyzx85
                      Thought I'd get one of these, seemed to be a good deal.
Name:	Screenshot 2025-11-01 at 6.08.31 PM.png
                        Replaced detents on top of the transmission, roller with a spring on the side behind the GPS, and shifter rod seal. Guess I now know why the shifter was popping out intermittently 😂😂 The shifting feel is much tighter now than before.
                          Subframe (plates + topside brace)
                          RTABS
                          Diff bushings
                          Pinion and axle seals
                          Rear ball joints
                          Rear adjustable LCAs
                          Front control arm bushings
                          P/S pressure hose
                          P/S pressure regulator shims (added 2)
                          Poly steering shaft flex coupler
                          Megan headers
                          (Been dicking with it for a few weekends but wrapped it all up today).
                            Sanded the primer on the repaired area and super happy with the result, I cannot tell where the damage was. I just need to finesse the edge, it may not be perfect but for the untrained eye, nothing happened there
                              I found a local set of BBS RSII. Will be polising them, installing PS4S tires and waiting to find a clean E46 M3
                              Instagram : @gc.m3sg
                              2023 M3C Xdrive British Racing Green
                              2003.5 M3 Silver Grey 6 speed
                              ______________________________________________
                              Miles End Composite CF CSL front bumper/Diffuser/Trunk
                              ST Suspension/CSL Rotors/Full Magnaflow exhaust
                              BBS RSII/Avant-Garde CSL Reps
                                Rear headrest go-pro bracket for POV on these amazing fall evenings (used an older action cam to test):
                                Click image for larger version  Name:	Screenshot_20251104-125125_Instagram.jpg Views:	0 Size:	54.8 KB ID:	325486Click image for larger version  Name:	Screenshot_20251104_140820.jpg Views:	0 Size:	145.3 KB ID:	325487
