Great DIY write up in the pinned post! I just have found a ton of conflicting information on what fluid to use for the e46 m3. Turners / ECS kits have CHF power steering fluid or redline power steering fluid but some forums say DO NOT USE CHF. ATF Dex 3 or better seems to be the other popular opinion. If someone smarter than me could shed some light, much appreciated.
Power Steering Fluid
If you replace the reservoir as part of the refresh or you simply want to replace the filter (which you cant because it's built into the reservoir), the new OE BMW reservoir cap is stamped to use CHF. I've been running CHF for about 20k miles.
I know this doesn't help.
Youtube DIYs and more
Figured I'd throw my 2-cents in here too. Just refreshed mine while doing a rod bearing job. Used Valvoline Maxlife ATF, as it's a full-synthetic DEX3/4 compatible ATF. Castrol multi ATF and Redline D4ATF that bidjae46 are also very good choices. Really, just about any Dex3 compatible ATF is fine in there.
Originally posted by Feffman View PostTrusty old Mobil-1 ATF has worked like a charm. A friend suggested I zip tie a "diaper" (oil soaking material from a parts store) around the top of the power steering reservoir. This too works well.
Feff
Originally posted by r4dr View PostThe PS cap says CHF because BMW has one part numbers for all cars. Factory fill through E46 was ATF, E90 started using CHF. I believe there’s a sticker that goes on top of the cap that says ATF.
Originally posted by timmo View PostThat's not the problem. My o-ring is new, at the track the fluid comes out of the vent hole in the cap.BMW / E46M Interior & Trim Restoration.
