If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Nah, I don't believe our pistons are forged, I have never heard piston noise on our engines like a POS GM V8 slapping pistons around and idling is not recommended in the owners manual. Unless your engine is not stock, then you can decide your own warm up .
You’re correct, stock pistons are cast. Mine are forged and have a little extra room because I run just under 30 psi on stock compression.
I normally wait long enough for the secondary air pump to shut off (45 sec-1 minute?) if you observe the ignition timing for warmup/emissions it starts near 0 advance (you can hear some interesting combustion sounds in the during the first few seconds from the late ignition timing) and ramps up slowly to the base timing.
Once the SAP shuts off thats my cue. Nothing magical about it but its at least enough time to get the cats warmed up and an easy and consistent marker to work with
All cold start is doing is adding air to the exhaust to lean it out to get hotter (post-combustion, not like your engine burning lean). You should just drive, cold start or not.
I mostly do it cuz im ignorant on this and i like to stay on the side of caution. But if youre right thats what i should do tho
On the secondary injection pump sure, but the motor itself runs rich when in cold start (open loop)
