What dash cams are you guys using on your M3s? I'm looking for something under $100 that is low-profile and doesn't stick out like a sore thumb.
Dash Cam Recommendations
https://www.instagram.com/individual_throttle_buddies/Tags: None
Aukey DR02 Dash Cam from Amazon, hardwired by tapping into the power cable for homelink. I hit a pothole a while ago, and the footage from the dashcam helped me put together an airtight claim for $2k from the municipal government.
- Likes 2
I have a Viofo A119 V3 in mine. It's also tapped into my Homelink wire.
There are lots of choices out there. It took me a while to decide on the Viofo but I've been happy with it."your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
yeBoth sound like good options, thanks for the recommendations. The fact that they wire into the homelink makes these real attractive over something that would dangle down into the 12v plug.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
I have the Viofo A119 too. Pretty basic, inexpensive and reliable.
Already saved somebody's ass too thanks to it!IG: @limited.slip
Alpine White 1 Series M Coupé
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
I use OldShark, actually use it mainly for track videos. 12v into the lighter though, but t's only like $50.
Youtube DIYs and more
If no homelink, where else are people tapping into?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I've got a Garmin 65W. Hides completely behind the rear view mirror and I can't see it at all when I'm driving (which is exactly what I wanted).
Homelink 12V is switched and you need constant 12V to get the parking recordings to work. I ran a constant 12V line from the cigarette lighter behind the radio and glovebox, up the a pillar and into the headliner. Got switched 12V and ground from homelink.
Tbone, all NA cars should be prewired for homelink, regardless of whether the car came with the device or not. Just gotta dig around to find the connector (unless you removed that wiring of course).2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
There should still be a homelink connector tucked in there and wrapped in cloth tape.Originally posted by Tbonem3 View PostIf no homelink, where else are people tapping into?
IG: @limited.slip
- Likes 3
