Square Setup
This man speaks truths, Montreal is the grand canyon in terms of road quality, horrid.Originally posted by Gt4 View Post
Roads in Ontario are fine compare to Quebec province...2006 Silber Grau Metalizat ZCP 6 MT
Montreal is un-drivable in a lowered car. It would be a Grand Tour special it's that bad.Originally posted by Gt4 View Post
Roads in Ontario are fine compare to Quebec province...2004 BMW ///M3 Carbon Black/Cinnamon 6MT Dinan S2 FBO NA Build
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R+
2019 VW GSW S 4MO Platinum Grey/Black6MT Daily
To revive this thread…anyone on 9.5J Comp/CSL Square setup? What do you run? 235?
I have currently 255/35 Michelins as square setup (9.5J et27) and get hard rubbing on full lock at the inner plastic wheelhouse. Coilover/camber+caster plates are installed but there is no possible setting without rubbing on full lock.
…under construction.
You mean 265?
Don't go any narrower than 255 on a 9.5" wheel. People fit 9.5et22 with 265 tire and -3 camber all the time. Et27 would be even easier to fit.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
The 35 section height is your problem. On a 19, it needs to be 30 and on an 18, it needs to be 35 to not rub on the inner and outer fender liner for most tires. Square 9.5 should be 265/30/19 or 265/35/18.Originally posted by S54B32 View PostTo revive this thread…anyone on 9.5J Comp/CSL Square setup? What do you run? 235?
To be fair, 255/35/19 IS the stock tire size (for rear)DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Obviously.
Doesn't change the fact that 255/35/19 is a stock tire size on a 9.5" wide wheel. I think it should fit. He prob needs more camber. Yes, a 265/30/19 is slightly smaller.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
That tire will not work for the problem he is having - "get hard rubbing on full lock at the inner plastic wheelhouse." The issue is not the width of the wheel and the tire.Originally posted by Tbonem3 View PostObviously.
He can try a 3mm or 5mm spacer.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Tried from 1 to 5° camber to check if it makes a difference, even played with caster. But nothing helped.
when I add a spacer, it will get even worser because the tire edge will be more pushed into the the plastic on full lock.
I will try a 245/35 next, maybe the problem is the Michelin tire with its very wide edge compared to Falken or other tire brands.…under construction.
I would try 265/30/19 which is the proper tire size for 9.5" (CSL wheel) rather than 245.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
