Brake Bias Calculator Help
    Hey guys. I’ve been trying to get access to clawhamm3r’s brake bias calculator google sheet, but my requests to access the sheet have not been approved for over a week. I was hoping someone with access to it would be able to plug in some numbers and let me know what the bias is for a front StopTech C43 BBK paired with stock rear brakes and with a 996 rear conversion. Measurements for the C43 front kit below..please let me know if you require more info.
    38/44 mm pistons
    332mm rotors
    50 mm or 43 mm radial pad depth (two options, prob will go with 50)
    Thanks
    997.1 GT3 Carrara White/Black
    C43 AMG Diamond Silver/Red​
    I made a copy awhile back and I can share it with you and you can copy it to your drive. I think I inputted everything correctly here:
      Do you have a ZCP or Regular M3, MK20 or MK60?
        This is what I estimated for the different setups you have in mind
          What do you include in the torque calc after the piston area calc?
          Youtube DIYs and more
              I run a st40 996 setup and it is to front bias for my liking. I am planning on playing with pad compound this year to see if I can get the feel I am looking for worst case I have a booster delete with bias adjustment to push it back a little. Car has been down for over a year so I cant really remember how bad it was just that I didnt like it.
              Jeff
                Thanks for sharing. Looks like 996 wouldn’t be ideal.
