Hi folks, first of all I hope you all are having a great christmas time
So, I´m into the proccess of the subframe reinforcing, and have a question about the rear plate bushings/bolts at the diff installation:
When I bouth the car she cames with the black series bushings at the plate, which I´m swapping with the E36 M3 OEM bushings, as I prefer these not as hard bushings at the diff.
Picture of the car with the rear off, I hope you can see the bots at the rear bolts of the plate, have a washer...
SO, if I remember at my ex M3, the bolts were directly connected to the bushings without any washer, like these images and video that I found out there...
As i´m going to install everything again, I don´t know If I might do it with or without the washers, the realoem shows a washer, which I don´t know if sits inside the bushing or outside as my car shows with the previous setup, as I didn´t buy yet the bolt/washers (parts 3 and 4 at the diagram)
https://www.realoem.com/bmw/enUS/sho...diagId=33_1065
Do normally the OEM washers/bolts sit inside the OEM bushings? The previous picture shows a big washer sitting at the outside, but I´m guessing that this is the "aftermarket" way of installing the polyurethane bushings...?
