Originally posted by heinzboehmer
View Post
Solid Mount Short Shifters: CAE / IRP / RTD / AAF / Coolerworx
Was about to post the same thing. I couldn't deal with a 2' lever on a Dd. Wonder why there isn't a short version. Ugh, just thinking about that snick snick feeling has me itching for a manual...
Originally posted by jareds941 View Post
Coolerworx “non-pro” and RTD mini are 11.8” tall from the tunnel...there are also more traditional short shifters from brands like UUC and BW that I left off of this list as they are what I’d consider a different type of short shifter. The AAF one also appears to go shorter, although I don’t know how much.
Originally posted by staylurking View Postalso just as a datapoint. I tried purchasing a RTD shifter yesterday and the CC system on the site isn't working. Tried emailing and contacting through FB and haven't received a reply. Not sure if the pandemic has the business on pause?
Originally posted by ra2fanatic View Post
The RTD has a self-centering spring, it definitely has a nice "pop" into certain gears, but it also looks kinda weird in each gear. First off, at least in my vehicle, neutral was canted waaaaay over to the right, so 1st gear looked like you were in third and 5th was somewhere in the ocean. 6th gear was really hard to get in to. I had a second shop try to adjust it, and the most slightest of loosening the 4 bolts and tightening them back down made 5th and 6th slightly better, but it didn't feel great. Also, when you put it into any gear, it still has a lot of motion left and right. You pop it into first and it has the tendency to "flop".
CAE, I've had 3 prior to this one, so I knew it was a no brainer that it would be great. I was reluctant to cut my center console, but after the bit of time with the RTD, the CAE was going to be the inevitable install.
Originally posted by r4dr View PostDoes anyone with experience using a CAE also have experience with the AKG shifter? Out of curiosity.
Originally posted by r4dr View PostSelector rod joint is separate from the DSSR isn’t it? Ideally both would be new.
Originally posted by staylurking View PostCan someone confirm if the Coolerworx "non-pro' comes with the self centering spring? That might be the deciding factor for those looking into a manual conversion.
Youtube DIYs and more
I have both a RTD (the one with the smaller base and no lockout) and a CAE and end result is about the same once adjusted properly. RTD fits with no modifications, but leaves the hole in the tunnel open (have not looked at solutions for this since I don't care on the car it's on). The CAE comes with a kit to close it up.
For a street car with semi frequent use I dislike both of them, the high shifting effort is just annoying. Wish there was a solution with the same precision but smoother\lower shifting effort and a shorter lever. Shortening the lever as it is doesn't work as then the effort required just gets stupid.
