Installed ohlin R&T several months ago. Only issue I have is ‘chatter’ from the rear, primarily at low speeds when going over small bumps. Read through a lot of posts but could not find anything specific. Any one experience this issue or have ideas of how I can fix?
Ohlin R&T noise in rear
I noticed that too and thought it might be due to the wheel hub in a dropped position, thought it might reposition after the car was back on the ground but can’t get a good view. Was actually looking at Difftech articulating perch which is supposed to address the angle but it’s $400 and want to make sure it’s worth it.
It's the perch not sitting flush with the control arm. Depending on the casting of the BMW aluminum control arm, either the Ohlins perch will get stuck on the mounting point or it will be sitting at an angle causing it to make noise. With the Ohlins hardware, nothing can be done to fix it. They should have made a bolt and washer that clamps the perch to the control arm.
Adding the RE reinforcement plate to the control arm did eliminate the noise, but the perch will sit 2mm higher off the mounting point.
I put my ohlins rear adjuster/perch down on some 1/8" thick rubber - no noise at all ever.
I also used the stock upper rubber pad rather than the plastic little disc Ohlins supplies. A little less VH, and no N (noise).DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
