Ohlin R&T noise in rear
    I put my ohlins rear adjuster/perch down on some 1/8" thick rubber - no noise at all ever.
    I also used the stock upper rubber pad rather than the plastic little disc Ohlins supplies. A little less VH, and no N (noise).
    I do the same. No noise.
    🔹 2001 M3 Laguna Seca Blue
    Instagram: link
    Build thread: link
      On the rear shock: the threaded portion is secured into the gold anodized portion of the damper with the lock ring. Make sure that is tightly secured, because it can loosen over time and use.
