SMG Lightweight Flywheel Options?
    Detent springs
    Selector knuckle/joint
    Clutch fork, clip and pivot ball
      Originally posted by Triqzy View Post
      . As a side note, during a clutch replacement are there any other things I should consider doing "while I'm in there"?
      Here's a good list of things to change if you want a good refresh:
      I'm getting ready change out the clutch in my car. Plan on replacing it with the Luk kit and using OE throw out and pilot bearings. Since the trans will be out of the car, I plan on replacing all detent springs, rear main seal, driveshaft centering sleeve, and shifter bushings. I was thinking of doing the seals for the input,
        Very informative thread thank you for linking.
