Rod Bearing Showcase Thread
  • Notan_S54
    My contribution to the thread. 05 car with 125k miles!
    Daily and mountain spirited driving on the car.
  • sapote
    Originally posted by BTB View Post
    This was from a few years back, but for the records … about 109k on engine. Engine is from an '06 model year and presumably had original bearings. I put the previous 55k miles on it including maybe 6 track days
    OH also under my ownership I drove this thing through cold Chicago winters, those super cold mornings didn’t help much I’m sure
    right side halves are the top?
    Not bad for 109K with some track days. This is good to have in the record.
  • BTB
  • Go3go
    Good wear patterns; Could run another 30K miles.
    How often redline? Track? Hard acceleration?
    Good to know! I just got the car last year so I can’t speak to the previous owner’s driving habits. I’ve put about 6k miles on it but they’ve been pretty tame since the car needed quite a bit of preventative maintenance (vanos, cooling system, bunch of bushings, diff reseal etc). No track time, maybe a couple redline pulls a week (which will change now that I’ve got the car more sorted). Otherwise just freeway cruising to work at 3k.
  • sapote
    Unknown mileage on bearings, 95k mile odometer 2001 spec.
    Must be a second set bearings as they still have plenty of life.
  • bavarian3
  • sapote
    Originally posted by Go3go View Post
    Out of my 2003.5 6 speed, 75k miles. Cylinders 1-6 left to right, uppers on the top row. Not terrible but glad I went ahead and did them.
  • Go3go
  • heinzboehmer
    wow, they look not bad for 183K miles! What was the mileage when you bought it and what makes you to inspect/change them now instead of around 100K?
    Mileage when I bought it was 183,968 mi lol. Didn't even drive it home after buying. Had it towed cause I knew the bearings were original.
    ​​​​​​If I had owned it when it had 100k mi, I would have changed them then.
  • sapote
    These came out of a late production car (04/25/06 build date) with 183,968 mi on it:
    I was told that they had never been changed. Not bad for the mileage!
  • heinzboehmer
    Click image for larger version  Name:	20240107_191945.jpg Views:	0 Size:	108.2 KB ID:	248345
  • stephen
    Not M3 bearings but these are the bearings that came out of my 2000 M5. 130,500 miles.
  • R1pilot
    Originally posted by R1pilot View Post
    2004 with 95k miles. Tracked on r compounds, not sure it makes a difference.
    Looks like we are doing this again at 151k miles 🤬
    I will update once I get my report back from Blackstone, but last one was showing copper high at 16 ppm while lead was at 2 ppm. Might do BE and ARP this time instead of BMW bearings (these are WPC treated)
    Car runs fine, no noises or anything weird ... just did an oil change and found this:
  • MathewM3
    Originally posted by tlow98 View Post
    just to follow up here. The dealer network was searched. There is no evidence that these rod bearings were ever done by the dealer. And fwiw, the pics don’t really show how worn they were. There was copper of some sort on every top and bottom. The tops showed guide a bit, but never did the copper cross all the way across the bearing like you see in spun bearings or bearings that are about to spin.
    Recall service bulletin for the Rod Bearings at the BMW dealership is: 11 04 04 / LBL code 422 if that helps you trying to track down the recall history and performed maintenance.
    I have attached the PDF from BMW's recall.
  • tlow98
    Ok, here we go.
    211k miles. 2002 SMG convertible. I’m doing a full engine rebuild and just dropped the block, heads, pistons, and crank off at the machine shop. The piston and cylinder wear are well within spec so intend to re-ring, hone and go. The main bearings looked nearly new save for #7 that has slight wear.
    I have decent maintenance history and all
    major jobs were done at the dealer and show on the carfax. For non major jobs I also have Midas receipts for oil changes and a drain plug that was stripped and replaced at some point. So, yeah it was treated ok, but never looked after with an open checkbook.
    I believe these to be original. Not bad I thought?
    Every rod bearing, save for two, does show some sort of copper, however.
    https://imgur.com/a/KjjGweU
