Hello all, Im trying to diagnose an issue I have with my car. Ive recently started to encounter more surging than usual throughout the power band. The 2k one took place ever now n again but under full load I had it at 5k. I was wondering if anyone had an idea as to why this happens. I have no codes or pending codes on the car and have driven it 3,000 miles in the past month or so. Currently sitting at 128,000 miles. I redid the vanos at 118,00 miles: turbotoy hub, arp camshaft bolts, besians reseals, and upgraded chain guide. Used the BMW bridge, no knock off. I did not purchase the besians solenoid because, well i have no codes. I also did rod bearing work at 125,000 miles, with all OE parts. At the same time I changed the fuel pump, fuel filter, and all new OE injectors. Air filter and throttle bodies were cleaned as well. Any thoughts?
Causes for surging under throttle
The best thing to do would be to look at data while the car surges. I recently had a faulty fuel system code over a stupid MAF.This is my Unbuild Journal and why we need an oil thread
Do you have a stock tune? Any surging is unusual.Originally posted by Jersey_M3 View PostHello all, Im trying to diagnose an issue I have with my car. Ive recently started to encounter more surging than usual throughout the power band. The 2k one took place ever now n again but under full load I had it at 5k. I was wondering if anyone had an idea as to why this happens. I have no codes or pending codes on the car and have driven it 3,000 miles in the past month or so. Currently sitting at 128,000 miles. I redid the vanos at 118,00 miles: turbotoy hub, arp camshaft bolts, besians reseals, and upgraded chain guide. Used the BMW bridge, no knock off. I did not purchase the besians solenoid because, well i have no codes. I also did rod bearing work at 125,000 miles, with all OE parts. At the same time I changed the fuel pump, fuel filter, and all new OE injectors. Air filter and throttle bodies were cleaned as well. Any thoughts?This is my Unbuild Journal and why we need an oil thread
Dirty IACV, bad MAF, or vacuum leak would be the top suspects.Originally posted by Jersey_M3 View PostWhat is the easiest or best way to pull log data off the car?
Find jfoj thread on e46fanatics about obdfusion. It logs quite a few PID.Originally posted by Jersey_M3 View PostWhat is the easiest or best way to pull log data off the car?
Youtube DIYs and more
BMWLogger: https://bimmersoftware.com/bmwloggerOriginally posted by Jersey_M3 View PostWhat is the easiest or best way to pull log data off the car?
Testo: http://www.bimmerforums.com/forum/sh...ime-graph-view
I used Testo to do test my CSL map sensor. It's a pita to get working, because Windows, but it works great once it does.Originally posted by heinzboehmer View Post
I'm not looking forward to figuring that one out. What sensor are you using?Originally posted by liam821 View Post
I used Testo to do test my CSL map sensor. It's a pita to get working, because Windows, but it works great once it does.This is my Unbuild Journal and why we need an oil thread
I ordered a Bosch 0261230101 - it's the same part as the OE BMW CSL sensor but since it's a Bosch part number it's 1/3 the price. You can get it on Amazon for $41.Originally posted by Arith2 View Post
I ordered the sensor for the M50's manifold as it showed a cross reference in part numbers. Visually it's identical to the CSL one. Hopefully the internal resistance is the same. I'm only out $17 if it's wrong. The one I got is VNE so hopefully is doesn't crap out. It's all chinese garbage anymore.Originally posted by liam821 View Post
https://www.amazon.com/Bosch-Origina.../dp/B00BL747DCThis is my Unbuild Journal and why we need an oil thread
Once you get it working, you can use Testo to verify it's working correctly and returning the correct voltages.Originally posted by Arith2 View Post
