Hey guys. I’ve owned my 2001 M3 convertible since March of 2005. It’s basically a garage queen as of currently sits with 71k miles and purchased almost 16 years ago with 38k. The car turns 20 years old this year and I’m looking to hang onto it for a lot longer.
ive decided to do a refresh, modification, and preventative maintenance on the car.
Any advice, suggestions, “while they’re in there” is greatly appreciated.
Here’s what I had done this past spring.
New Eldor ignition coils
Ngk spark plugs
New pulleys, belts.
Optima red top battery
New oem headlight lenses wrapped in xpel.
New fog lights
Oem guibo, center bearing, driveshaft CV joint
Rogue engineering tranny mounts
Transmssion fluid/ diff flush
Cabin/engine air filter
New side markers, front turn signals
Fuel filter
New cigarette lighter and socket
New rear ashtray with roller.
New center console.
New windscreen
Bosch wipers blades
New jack pads
New sos mirror with homelink and new mirror glass.
Convertible top components refresh Oct 2020
New headliner
C pillar repair
New bosch convertible flap motor under rear seat.
Bulletproof hydraulic pump (top hydraulics)
New extended lines 23/24
Replaced “hall” sensor.
Rebuilt convertible top latches.
Airbag recall.
Parts I’ve been collecting since October but haven’t installed yet. I will be installing within the next few weeks. **Any recommendations while I’m in these areas would be great**
Eventuri intake
Euro headers and euro section 1
New oem header install kit and all gaskets for entire exhaust.
Fuse box fan (to get rip of the chirping sound)
ST front and rear sway bars.
New Moog front endlinks for my KW coil overs
Osram cool blue boost HID bulbs
New philips high beam bulbs
New oem motor mounts
Vac coated rod bearings with extra clearance
Vac oil pump upgrade kit
Redish Motorsport subframe reinforcement
AKG 95a yellow subframe bushings
OE diff cover.
Avin avant 4 head unit with most of the options.
Later this year
Either a vanos from vac along with the vac vanos hub upgrade or from Besian.
Possibly a Zhp steering rack, new tie rods, control arms, and control arm bushings. The car is definitely going to get fully wrapped in xpel ppf along with fresh new ceramic tint.
If I’m leaving anything out just let me know. I have most of the parts already, just waiting for the snow to melt so I can bring it to the shop.
Thanks.
Ngk spark plugs
New pulleys, belts.
New fog lights
Fuel filter
New center console.
New windscreen
Bosch wipers blades
New jack pads
New headliner
C pillar repair
Airbag recall.
Eventuri intake
OE diff cover.
Later this year
Thanks.
