Feeler: Girodisc 2-piece floating rotors for E46 M3
    Out of curiosity, how many of you guys would want to run the rears with the 996 caliper setup?
    I'm interested
      The reason I asked about the Porsche caliper rears is because of the pad (D738 I think) that gives ~5mm of clearance next to the e-brake drum which is where the issue lies. That being said, that would carve a niche out of a niche so a bit of a last resort. I'll update you guys when I have more.
      As far as the fronts go, that's not an issue at all. But that's why other people already make 2-piece rotors for that axle.
        Interested in a set of rears. I’m fine with using the narrower pads with Porch calipers..planned on using those anyways.
        Is it possible to make the discs in a bi-directional slot pattern? 🤔
        997.1 GT3 Carrara White/Black
        C43 AMG Diamond Silver/Red​
          Thanks, went ahead and updated my list of people in #2. If you have rear Porsche calipers and I didn't note it, let me know. That might be a clean, easy way to do the rears.
          For bi-directional slot pattern, can you clarify what you mean? If you're looking to run them on either side, that won't work anyway as the curved vanes are directional.
            996 calipers front + rear
            Formally SWRTstang_M3 on M3forum.net with a join date of 07/2004
              I would be interested in f&r as well.
                Are you running stock calipers front + rear?
                  Pcar Calipers F&R
                  For the rear caliper, I am running the larger D737 pad shape.
                    Joined the site after speaking with your sales department and hearing about this post. We run Giro front and rear set-up on our ACR Viper. They simply CANNOT be beat. Our favorite mod to our car hands down. I want some CSL discs for my E46!
                      I am in for some rears.
                      Just purchased a pair of PFC V3 fronts and wanted the full set but couldn't source them anymore.
                      2002 M3 Carbon Schwarz/Black 6MT
                        Slot pattern like this. But I’m perfectly fine with the standard slots, too.
                          Pcar Calipers F&R
                          Great, added you to the list. I'm hoping we can run standard pads (either with stock or Porsche calipers), but that D738 shape gives us a potential fallback.
                          Nice! Are you running stock rear calipers or Porsche calipers?
                          That's unfortunate about the PFC rotors, their parts are quality but sometimes scarce. What rear calipers are you running?
                          Ok, I understand now. Yeah, we'll probably stick with a standard slotting pattern to keep it simple and costs down.
                            Would we still be able to use the parking brake?
                              Yup. As far as I know, all our rotors maintain the factory e-brake.
                                I am running the 996 calipers.
