If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Pairing stages 1 & 1.5 of the CMP kit will provide a fairly comprehensive underside & topside fix provided you stitch weld problem areas of the chassis and only set you back $150 USD + shipping.
That paired with solid subframe bushes (To improve the handling/feel) is what I suggest for an initial reinforcement as if you ever go big power or get aggressive with your driving the kits are modular so, more can be added at a later date if need be.
I like the vincebar, both because it supports the fellow that actually figured out how to the address the fundamental engineering flaw of the chassis, and because it doesn't negatively impinge upon your truck space or look like you have anything installed once it's in.
