Wow I really like these seats, quite similar to the factory GT3 seats as you can see. Would love a set in the M3, these are a great mix between street/full race seats. They also look extremely good for the price, $1230 a side.
Cheapest place to get Nogaro's?
Originally posted by Tonggi View Postman those look so good. I may need to order a set sooner! HMS had a lot in stock?2004 Silbergrau Metallic 6MT
Originally posted by repoman89 View PostCan’t wait to install mine. Stock seats are out, just need to build up wiring harnesses for electric seat slider power and for the heater pads. This way I can sell my stock seats in a non-butchered state. I couldn’t figure out how to access the second upper heater plug anyway to unplug it.
I haven't even looked into the M3 install but after putting these in the 996 I just know at some point the M3 needs a set as well.
Did you get the "Street" or "Circuit"? I am think I would get the Circuits as I like the look plus the obvious track benefits if I ever get into that, very doughtful in this vehicle though.2004 Silbergrau Metallic 6MT
I'll be interested to see how hard the install on the M3 will be and would be quite interested in any info, I want seat heats and manual sliders. I currently have power seats/seat heats.
I got the circuit, no reason not to imo. I barely drive this car on the street and am just getting into track. Probably will be at least 50:50 track:street usage for me going forward.
Originally posted by Mpower04 View PostI'm considering these over Pole Positions I've had previously. Are you still enjoying them?
Originally posted by ridebikes View Post
I recently put these in my car and love them. It's snug, well bolstered, but not hard to get in it out of. Highly recommend! Though if you have PPs, it might be a bit of a lateral move 🤷♂️
Originally posted by Obioban View PostI’d say PPs are slightly better on track, the Nogaros are significantly better on street.
Good to know, thanks! I had the PPs in my E92, I don't have it anymore. I did love them though, just not where the seat belt receptacle laid.
AFAIK, you have to get them shipped from europe, but I think it's worth it because the seat belt will act in the way that it was designed to during a crash.
This is not an issue on the nogaros because of how low the side of the seat gets.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
If you do get PPs, try to get the PP ABE. The opening for the seat belt receptacle is significantly bigger on those, so you can use the stock pretensioning one and still have the belt lay flat on your lap, instead of having it go over the side of the seat or having to use a rear non-tensioning receptacle.
I loved the support the PPs offered. I had Sportster CSs after because I needed seats that folded and I did not like them. (bolstering, lateral support, seating position)
