Driveshaft play
    Originally posted by erickhoyos View Post
    Thanks for the tip. Question now is if it is the clutch, what brand clutch/flywheel would be good for daily driving with a bit of spirited driving every once in a while? OEM or stage 1 is what I aim for
    For an SMG car, OE SACHS or LUK
      How common is it for the u-joint to go bad on these? As I understand this would be the only real reason to get a different driveshaft as the UJ isn't serviceable.
      Not very common.
      One advantage of a rebuild is the driveshaft is dynamically balanced. I would say that you can get a rebuilt unit for about the same price as replacing all of the consumables and the rebuilds come with a 12 month warranty.
        Not very common.
        I haven't messed with the DS in the past beyond replacing the Guibo/csb, but my CV seal has taken a dump. Best bet to just pick up a rebuilt unit over chancing the CV replacement?
        CSB and Guibo could be done again I suppose, it's been about 30k miles since last service.
          I’d check the CV. Probably can just repack with grease and install a new gasket.
            Driveshaft vibrations come from 4 possible sources, really - CSB, Giubo, U-joints, and diff CV. The first two easy to replace and should be at that point anyway, and the other two are pretty easy to isolate and diagnose.
