Originally posted by SteelGreyM
You’ll need 2 fittings to screw into the brake line ports to bench bleed the master cylinder. Not sure if a regular brake caliper bleeder screw will work. Put the master cylinder in a vise and then run hose from the ports back to the reservoir. And then fill and them pump the piston with your hand.
Install the master cylinder. Bleed in the system, actuate the ABS pump and bleed some more.
I used Walmart DOT 4 and once everything was good bled Motul into the system, actuated the ABS pump, bled some more.
