Dinan S3r Kit Adaptation to Technica Manifold
    So I am currently in the process of trying to have the Dinan s3r kit work with a Technica manifold so that I can eventually run more boost. I plan on getting rid of the Dinan recirculation system for a Tial blow-off valve and was wondering if I were to do so what spring would I have to use. I see that Tial says to use a -2 psi spring for supercharger applications but would that apply to centrifugal superchargers as well?
    Would it potentially be possible to still use the dinan recirc calve as a blow-off by just not plumbing the side that lets the air out?
    I’m using the lowest spring rate on my setup with a Rotrex blower.
    you can vent the BOV to the outside if u like the noise vs quite
      Yeah I had to get a lighter spring on my GFB valve.
      The Vortech Maxflo is setup as a recirc valve, but Vortech does make a straight BOV.
      2004 Dinan S3-R M3
      2023 X3M Competition
