VF570 Maintenance/Replacement Parts Thread
    Hello everyone, can somebody tell me if on the vf570 the water/air cooling system is connected to the car regular cooling system? Or is it independent? If it is do you have to change fluid on the manifold cartridge and/or the front water radiator? Thanks in advance…
      It's independant.
        Have you done a dyno run after the 2.62? How much did you pick up vs stock pulley?
          Originally posted by Martyn View Post
          It's independant.
          Thanks..that's what I thought….had my kit for like 8+ years and I never checked/ changed fluid. So was wondering if that's something that's supposed to be done. I purchased car with the kit already installed and even though I've removed manifold , blower etc, I never removed radiator that came with the kit.
            I've not yet hit the dyno unfortunately.
              Got the car on the dyno over the weekend, I made the following on the stock MSS70:
              561.2 flywheel bhp, 400+ lbft torque. I didn't bother to make any further adjustments as I wanted to spend the timing dialling in the MaxxECU.
              And with my MaxxECU Race and some tweaking, I still have a little work to do on the mid range ignition timing to bring the mid range up to match that of the MSS70.
              What was really interesting though was the air temps coming straight out of the supercharger (pre charge cooler) and it would start at ~35*C and end at 100*C on a 4th gear pull yet the post charge temps only climb a few degrees.
              Click image for larger version  Name:	2023-04-03-11_01_15-Mtune-Log-Viewer-log_2023-04-01_124758.jpg Views:	0 Size:	30.6 KB ID:	212352
              Just goes to show 2 things, the compressor is probably way out of it's efficiency range running a 2.62" pulley, and the charge cooler does a great job.
              By the way, the car is on it's original head gasket and 143,000 miles!
                The difficulty dissipating heat when SC'd has always been has always been one of the big knocks against FI for our cars. Would be interesting for you to get out on a track and really beat on it.
                  Hi! Do you guys still have this setup? If so, any issues with cooling etc?
                    Bookmarking this for later. Thank you guys
                    I think it’s safe to assume the cooling reservoir is not an off the shelf piece but does anyone know where I can get a replacement stopcock for it? o-ring is ok but the stopcock it self took some damage.
                      Upper Idler Pulley (mounted to the VF SC bracket) - 76mm x26mm with 17mm Bearing ID.
                      Dayco 89017
                      Conti 49011
                        Having just purchased a used VF570 kit from an E46 M3 I had some fun sourcing some spare bits for my Z4M, obviously VF can provide the bits but they were very expensive, so I set about sourcing bits myself.
                        Mechanical Tensioner: 1128 1 427 252 or VKM 38202
                        Idler Pulley (INA): 532000110
                        Check Valve: Any check valve with an 0.275" or 6mm inlet/outlet will do.
                        IAT Sensor (Bosch): 0280130039
                        Belt: 6PK2040 (I'm running a 6PK2033 with the 2.62" SC pulley).
                        Air filter: K&N RU-3130
                        SC support bracket to oil filter housing bolt: M8x120mm 12.9 Cap head. Trim this down to ~110mm if need be.
                        Lower alternator bolt: 1x M10x1.5x160mm
                        Lower alternator spacer specs: 25.0mm O/D, 10.5mm I/D, 18.0mm Width.
                        Throttle body to charge cooler plenum boots: 6x BMW 11617835861 worked fine for me. Tuner Motorsport Silicone couplers also work fine: PN: 003313TMS03KT
                        SC Pulley:
                        • Stock size for the VF570 kits according to VFE is 2.87", Vortech part number: 2A036-287.
                        • A 2.7" pulley is available via VFE and the part number is CB257A
                        • A 2.62" pulley can be purchased via Vortech, part number 2A036-262. A 2.62" pulley puts you at just under 51K impeller speed at 8200 RPM so you probably don't want to go any smaller than this as the blower has a limit of 52K!
                        Vortech SC Oil: 009035
                        Spark Plugs: 6x NGK DCPR9EIX (Iridium) or 6x NGK DCPR9E (Copper)
                        Charge Cooler Radiator (NRF): 50547
                        FPR (BMW): 3.5 Bar - 13531729319 or Bosch 0280160597
                        Injectors (E46 M3): Bosch 0 280 158 117
                        Injectors (Z4M): Bosch 0 280 156 012
                        Water Pump: M-8501-L54
                        Charge Cooler lines: 19mm / 3/4" Heater Hose
                        Crank Case Vent lines: 16mm or 5/8" Oil / Fuel Hose
                        Top Radiator Hose (E46 M3): Remove the OEM clips from the stock radiator hose, remove the plastic ends and switch them to the opposite ends and re-clamp.
                        Top Radiator Hose (Z4M): Purchase 2x 38mm 45* silicone bends and a 38mm hose joiner. Trim the ends to suit and join with a hose coupler. VFE wanted ~$350 for their own hose.
                        Supercharger outlet to inlet manifold coupler: A 70mm x 75mm silicone straight is a better fit than the OE VF hose, trim it down slightly to suit.
                        Big thanks to Tom, aka Harber07 for his help with some of these bits.
                        I hope this helps!
                        Cheers
                        Martyn
                        Does anyone know which spark plugs are the best?
                          Spark plugs: NGK 2641 - DCPR9E
                          Been running those on my VF570 set up for 15 years now.
                          i replace them every 20000kms because they are cheap.
                            From all the research I've done so far everyone's saying to go with the NGK DCPR9EIX (Iridium) Have you tried the Iridium version? And what oil are you running? I'm thinking High Performance Oil - Red Line 10W60
                              The fine people at VF told me to run those spark plugs and I haven’t bothered to venture trying any others.
                              as for oil I had always bought BMW TWS 10w60 from the dealership till I switched to liquid-moly 10w60 for a few years and now back to BMW dealership 10w60 only because I got 20 cases of it for a wild deal when the they closed up shop.
                              i was left unemployed but got a lifetime supply of oil lol
