Having just purchased a used VF570 kit from an E46 M3 I had some fun sourcing some spare bits for my Z4M, obviously VF can provide the bits but they were very expensive, so I set about sourcing bits myself.
Mechanical Tensioner: 1128 1 427 252 or VKM 38202
Idler Pulley (INA): 532000110
Check Valve: Any check valve with an 0.275" or 6mm inlet/outlet will do.
IAT Sensor (Bosch): 0280130039
Belt: 6PK2040 (I'm running a 6PK2033 with the 2.62" SC pulley).
Air filter: K&N RU-3130
SC support bracket to oil filter housing bolt: M8x120mm 12.9 Cap head. Trim this down to ~110mm if need be.
Lower alternator bolt: 1x M10x1.5x160mm
Lower alternator spacer specs: 25.0mm O/D, 10.5mm I/D, 18.0mm Width.
Throttle body to charge cooler plenum boots: 6x BMW 11617835861 worked fine for me. Tuner Motorsport Silicone couplers also work fine: PN: 003313TMS03KT
SC Pulley:
Vortech SC Oil: 009035
Spark Plugs: 6x NGK DCPR9EIX (Iridium) or 6x NGK DCPR9E (Copper)
Charge Cooler Radiator (NRF): 50547
FPR (BMW): 3.5 Bar - 13531729319 or Bosch 0280160597
Injectors (E46 M3): Bosch 0 280 158 117
Injectors (Z4M): Bosch 0 280 156 012
Water Pump: M-8501-L54
Charge Cooler lines: 19mm / 3/4" Heater Hose
Crank Case Vent lines: 16mm or 5/8" Oil / Fuel Hose
Top Radiator Hose (E46 M3): Remove the OEM clips from the stock radiator hose, remove the plastic ends and switch them to the opposite ends and re-clamp.
Top Radiator Hose (Z4M): Purchase 2x 38mm 45* silicone bends and a 38mm hose joiner. Trim the ends to suit and join with a hose coupler. VFE wanted ~$350 for their own hose.
Supercharger outlet to inlet manifold coupler: A 70mm x 75mm silicone straight is a better fit than the OE VF hose, trim it down slightly to suit.
Big thanks to Tom, aka Harber07 for his help with some of these bits.
I hope this helps!
Cheers
Martyn
SC Pulley:
- Stock size for the VF570 kits according to VFE is 2.87", Vortech part number: 2A036-287.
- A 2.7" pulley is available via VFE and the part number is CB257A
- A 2.62" pulley can be purchased via Vortech, part number 2A036-262. A 2.62" pulley puts you at just under 51K impeller speed at 8200 RPM so you probably don't want to go any smaller than this as the blower has a limit of 52K!
I hope this helps!
Cheers
Martyn
