As others pointed out you will need a new airbox over 6 to 6.5 PSI and at that point you mind as well get a different kit rather than try to reengineer your own kit. I only say that because if you do not get it dyno tuned you will run into some headache. Since you will change injectors, pulley, manifold, intercooler (basically a new kit).
Is it possible to get more power with Dinan S3-R?
That's fair. I am just going by what ESS (Roman) used to say and why they transitioned to a cast manifold for their higher-level kits back in 2005. But, hey try it and report back!Originally posted by 9kracing View Post
People always say this and it's simply not true.
The airbox is fine up to at least 10 PSI, and you'd be well over 500WHP by then.Tanzanite F80 2018 OEM+
Silver Grey E46 M3 2004 OEM+
